OpenDocument Text Format Attributes
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
Attribute Name
Contents
fme_doc_break_count
How many sequential page breaks are present.
fme_doc_font_bold{_header}
Indicates whether the text is bold.
fme_doc_font_color{_header}
A comma-separated string of three floating-point RGB components normalized to [0,1].
fme_doc_font_italic{_header}
Indicates whether the text is italicized.
fme_doc_font_name{_header}
Font name.
fme_doc_font_size{_header}
Font size in points.
fme_doc_font_strikethrough{_header}
Indicates whether the text has a strikethrough.
fme_doc_font_underline{_header}
Indicates whether the text is underlined.
fme_doc_heading_level
Heading level.
fme_doc_heading_text
Text to be displayed for a heading.
fme_doc_image_filename
When fme_doc_image_source is FromFile, this contains the file path to use.
Indicates whether the image is from a feature's geometry or a filepath.
Values: FromFeature, FromFile.
fme_doc_image_width
Width of the image.
fme_doc_justification{_header}
How the element should be aligned.
Values: Left Justified, Centered, Right Justified, Fully Justified
fme_doc_list_level
List level.
fme_doc_list_ordered
Indicates whether the list is ordered or unordered.
fme_doc_list_text
Text to be displayed for a list item.
fme_doc_measurement_units
Measurement units of width attributes.
Percentages are relative to the page width.
Values: Inches, Centimeters, Points, Percentages.
fme_doc_paragraph_style
Name of style applied to a paragraph.
fme_doc_paragraph_text
Text to be displayed for a paragraph.
fme_doc_table_col_header
Text of the first row of a column.
fme_doc_table_col_value
Text of the current row of a column.
fme_doc_table_col_width
Width of a column.
Values: A numeric value or Stretch.
fme_doc_table_style
Name of style applied to a table.
fme_doc_type
The type of document element.
fme_doc_use_markdown
Indicates whether any text has markdown symbols:
  • Bold: **text**
  • Italic: _text_
  • Underline: --text--
  • Strikethrough: ~~text~~
  • Link: [text](url)
