Neo4j Reader Parameters
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Note that Database Connection parameters differ slightly, depending on context and/or database format. |
Connection From the Connection parameter in a database format, you can do one of the following:
Database Connection
Select an existing Neo4j connection, or Add Database Connection...
Add Neo4j Connection To define a new connection from the Connection parameter in a Neo4j format, see the topic Neo4j: Add Database Connection. |
Include transaction-local element IDs
This parameter controls whether the results of Cypher queries executed by the reader will include the transaction-local element IDs assigned by Neo4j. This can be useful to check the uniqueness of nodes and relationships returned from a query.
Constraints
The constraint parameters can be used to read only a subgraph of the database.
Node Labels – Only nodes with at least one of the labels specified by this parameter will be read from the database. If empty, then all nodes will be read regardless of their label, subject to the relationship types constraint.
Relationship Types – Only relationships with one of the types specified by this parameter will be read from the database. If empty, then relationships with any type will be read, subject to the node labels constraint. When relationship types are specified, disconnected nodes are no longer read.
