Google Sheets v4 Writer Feature Type Parameters
Important  These parameters apply only to a selected feature type, not to the entire writer. If a feature type parameter listed here conflicts with a writer-level parameter, then the writer parameter will be ignored and this feature type parameter will be used.
Dataset
Row Selection
Schema Generation
Field Names Row
This optional parameter indicates the row number that contains the field names.
If not provided, then field names are column letters from Start Column up to End Column.
Start Column
The column from which to start mapping field names to user attributes.
Value: Must be a value between A and ZZZ.
End Column
The column at which to stop mapping field names to user attributes. The writer will write up to and including this column.
Sheet Options
Start Row
The row number of the first feature. The value must be greater than Field Names Row.
Interpret Values As
This specifies how the server should interpret attribute values.
  • User-Entered – Values are parsed as if they were entered through the Google Sheets web interface. Use this option when working with formulas.
  • Raw – Values are stored as-is.
Insert Method
This parameter is applicable only when Feature Operation is set to Insert.
  • Insert Rows – New rows are always inserted at the end of the detected table.
  • Overwrite – Existing cell values following the end of the detected table may be overwritten.
