Google BigQuery Writer Parameters
Service Connection
Credential Source
For Google Cloud authentication information, see Getting Started with Authentication.
  • Web Connection – Uses Google Cloud BigQuery API via OAuth 2.0 to authenticate and make requests.
  • Application Default Credentials – Automatically authenticate access based on the system environment. This will attempt, in order, to resolve credentials using the following sources:
    • The credential file pointed to by the environment variable `GOOGLE_APPLICATION_CREDENTIALS`
    • The credential file created by using the Google Cloud CLI.
    • The metadata server on a Google Cloud Engine Virtual Machine instance.
Note  See How Application Default Credentials works for more information on how Application Default Credentials are resolved.
About Web Connections
Connections store authentication information.
For general information about web connections, please see Using Web Connections.
For information about managing web services (including authorization credentials such as Client Id and Client Secret), please see Managing Web Services.
Connection
From the Connection parameter in a web service format, you can do one of the following:
  • Select an existing previously defined connection. For information, see the section Reusing a Web Connection in Using Web Connections.
  • Select Add Web Connection to define a new connection. The new connection can be made visible only to the current user, or can be shared among multiple users.
Account
Select web connection account for authentication.
Project
Select the Google BigQuery project.
Write Options
Table Handling
  • Write if Empty (default) – Load features to table only if the table is empty, or does not exist.
  • Append – Load features on a pre-existing table.
  • Overwrite – Overwrite the entire table with only the new features. All pre-existing data will be overwritten.
Dataset
The dataset to load features into. This dataset must exist before writing to it.
Number of errors allowed
The number of features allowed to produce errors and be ignored. These features will be skipped and not loaded onto Google BigQuery.
Value: Must be greater than 0.
Table Splitting
The number of features to write at a time to BigQuery.
The default is 0, in which features are written at the end of translation.
Spatial
Advanced
