Google BigQuery User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
The following table shows the attribute types that are supported.
Name |
The name (fieldName) of the column to be written. This is the programmatic name, which should not contain spaces or uppercase. |
Type |
The Google BigQuery data type for the column. Refer to Specifying a schema for details. |
Geometric Types
These are the geometric data types. Their values are in Well Known Text (WKT) format.
- point
- line
- polygon
- multipoint
- multiline
- multipolygon
Use the GeometryExtractor transformer to convert FME geometry into a WKT attribute. Use the GeometryReplacer transformer to convert a WKT attribute into an FME geometry.
