Databricks Writer Parameters
To define a new connection from the Connection parameter in a Databricks format: Select Add Database Connection, and scroll to Databricks.
See database-specific parameters below, as well as the section Adding a Database Connection in a workspace in Using Database Connections.
The new connection can be made visible only to the current user, or can be shared among multiple users. To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections.Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Note that Database Connection parameters differ slightly, depending on context and/or database format. |
Connection From the Connection parameter in a database format, you can do one of the following:
Databricks Credentials
Server Hostname: The URL of the Databricks workspace. This will take the format https://<workspace_id>.cloud.databricks.com/ or https://adb-<id>.azuredatabricks.net/.
Compute Type: Choose whether to run Databricks commands using an All-Purpose Cluster or a SQL Warehouse.
Cluster ID: The ID of the cluster used to run Databricks commands. This cluster must have access configured to the cloud storage location specified in the writer parameters.
SQL Warehouse ID: The ID of the SQL Warehouse to run Databricks commands with. The warehouse should be configured with access to the cloud storage location specified in the writer parameters.
Authentication Method: The method used for authentication.
Personal Access Token |
Connects using a personal access token from Databricks.
OAuth (Web Connection) |
Uses an OAuth web connection that accesses the Databricks service. This option enables the Databricks OAuth Connection parameter, from which you can pick a saved connection, or add a Databricks OAuth Web Connection.
Authentication Method |
M2M OAuth Connections |
U2M OAuth connections |
OAuth for AWS-hosted Databricks clusters |
See Authorize service principal access to Databricks with OAuth on the Databricks documentation website. |
See Authorize user access to Databricks with OAuth on the Databricks documentation website. |
OAuth for Microsoft Azure-hosted Databricks clusters |
See OAuth 2.0 client credentials grant on the Microsoft documentation website. |
See Authorize user access to Azure Databricks with OAuth on the Microsoft documentation website. |
Catalog: The catalog to write to. Each writer can only write to a single catalog. Click the [...] button to see a list of accessible catalogs in the workspace.
Cloud Upload Credentials
Storage Type: Amazon S3 | Microsoft Azure Data Lake Gen 2 | Databricks Unity Catalog Volume
Select the form of cloud storage to use as a staging area. The Databricks cluster selected should be configured with its own access to this location. The cloud storage credentials provided here will strictly be used by FME to upload data to the cloud storage location and will not be passed through in any Databricks commands.
When Storage Type is Amazon S3, these parameters are enabled:
- S3 Connection: An AWS web connection containing access key credentials for an AWS bucket.
- S3 Bucket: The name of an S3 bucket to upload staging files to. If the Amazon S3 FME Package is installed in Workbench, clicking the browse [...] button will display a list of buckets. Select only the buckets that are accessible by the Databricks workspace.
When Storage Type is Microsoft Azure Data Lake Gen 2, these parameters are enabled:
- Cloud Authentication Method: Provide Azure credentials through a Web Connection or a Microsoft SAS token.
- Azure Storage Connection: An Azure Storage Web connection containing an Azure storage account name and either an account shared key or an SAS token.
- Azure Storage Account: The name of the Azure storage account to use.
- Shared Access Signature (SAS): A valid Azure SAS token.
- Azure Data Lake Container: The name of the Azure Data Lake container. If the Azure Storage Connector FME Package is installed in Workbench, clicking the browse [...] button will display a list of containers. Select only the containers that are accessible by the Databricks workspace.
When Storage Type is Databricks Unity Catalog Volume, these parameters are enabled:
- Volume Catalog: The Databricks Catalog where the Unity Catalog (UC) Volume is located.
- Volume Schema: The Schema (or Database) within the catalog where the UC Volume exists.
- Volume Name: The Volume Name where files will be staged before being loaded into Databricks tables.
Unlike S3 and Azure, files uploaded to UC Volumes remain inside the Databricks workspace, eliminating the need for external cloud storage credentials.
Advanced
How many features to include in each write request. If this value is not specified, the default is 100,000.
This parameter allows for the execution of SQL statements before writing to a table. For example, it may be necessary to clean up a table before attempting to write to it. The statements will be executed only when the first feature arrives at the writer.
For detailed information about SQL functions, click the corresponding menu item in the .
to open the editor.Available menu options depend on the format.
Multiple SQL commands can be delimited by a character specified using the FME_SQL_DELIMITER directive, embedded at the beginning of the SQL block. The single character following this directive will be used to split the SQL block into SQL statements, which will then be sent to the database for execution. Note: Include a space before the character.
For example:
FME_SQL_DELIMITER ; DELETE FROM instructors ; DELETE FROM people WHERE LastName='Doe' AND FirstName='John'
Multiple delimiters are not allowed and the delimiter character will be stripped before being sent to the database.
Any errors occurring during the execution of these SQL statements will normally terminate the reader or writer (depending on where the SQL statement is executed) with an error. If the specified statement is preceded by a hyphen (“-”), such errors are ignored.
This parameter allows for the execution of SQL statements after a set of tables has been written. For example, it may be necessary to clean up a temporary view after creating it.
For example:
This setting enables the creation of tables without data features.
- No – Tables are only created when receiving data features.
- Yes – Tables are created without data features if possible.
