Esri ArcGIS Feature Service – Reader Feature Type Parameters
To access feature type parameters, click the gear icon Tip To always display the editor in FME Workbench, you can select View > Window Layout > Parameter Editor.
General All feature types share similar General parameters, which may include Feature Type Name, Reader or Writer information, and Geometry. In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept Table or Index Qualifier prefixes on the output table feature type. |
These parameters apply only to a selected feature type, not to the entire reader.
Constraints
These parameters are passed to the Query API endpoint of the Feature Service. For more information about these parameters, refer to the corresponding page in the ArcGIS REST API documentation.
Optionally specifies the SQL-style WHERE clause applied to object fields to limit the set of features returned. Attribute names are case-sensitive, and the types of values must match the type defined in the schema.
Optionally specifies the geometry to apply as the spatial filter.
The value should be valid Esri GeoJSON, a point of the form x,y, or a bounding box of the form xmin,ymin,xmax,ymax.
The type of geometry specified in the Input Geometry parameter. The server will return an error if the Input Geometry is not of the specified type.
This parameter is ignored if Input Geometry is not specified.
Options: Envelope (default), Point, Polyline, Polygon, Multipoint
The type of spatial relationship to use with the Input Geometry.
Options: Intersects (default), Contains, Crosses, Envelope Intersects, Index Intersects, Overlaps, Touches, Within
The optional buffer distance for the Input Geometry. Applies to all Input Geometry types.
The units used for the Distance parameter.
Options: Meters (default), Miles, Feet, Kilometers, Nautical Miles, US Nautical Miles
Whether curves in geometry should be preserved. If set to No, curves will be densified to lines by the feature server. The reader can only read Bézier curves when densified.
Options: Yes (default), No
on a feature type in the
