Esri ArcGIS Enterprise OAuth Web Service Template
To access the Esri ArcGIS Enterprise OAuth Web Service template:
There are two methods to create an Esri ArcGIS Enterprise OAuth template web service:
From Workbench FME Options
- Open FME Options > Web Connections > Manage Services.
- Select Esri ArcGIS Enterprise OAuth (Template) (safe.esri-agol) Web Service Setup Instructions and follow the instructions.
Note You will have to manually replace instances of "[ENTERPRISE_SITE_URL]" where it appears.
From the Reader/Writer parameter dialogs in a workspace
- Locate the parameter Web Connection and select Add Web Connection.
- Select Esri ArcGIS Enterprise OAuth (Template) (safe.esri-agol).
- Open the Web Service Manager link > Web Service Setup Instructions and follow the instructions.
