Airtable Writer Feature Type Parameters
To access feature type parameters, click the gear icon Tip To always display the editor in FME Workbench, you can select View > Window Layout > Parameter Editor.
General All feature types share similar General parameters, which may include Feature Type Name, Reader or Writer information, and Geometry. In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept Table or Index Qualifier prefixes on the output table feature type. |
Dataset
Feature Operation
This parameter specifies how records will be written into the destination table. Supported feature operations are described below.
Option |
Description |
If the Record Does Not Exist |
If the Record Exists |
Insert |
Adds a record into the table. |
A new record will be inserted. |
Not applicable. |
Update |
Updates an existing record in the table. A Record ID Attribute containing a valid record ID must be specified in the Row Selection group. |
If the record ID is invalid, the translation will fail. |
Changes only fields in the corresponding record which are contained in the input feature. |
Replace |
Replaces an existing record in the table. A Record ID Attribute containing a valid record ID must be specified in the Row Selection group. |
Changes fields in the corresponding record which are contained in the input feature.Fields not specified in the input feature will be set to NULL. |
Delete |
Deletes an existing record in the table. A Record ID Attribute containing a valid record ID must be specified in the Row Selection group. |
The writer deletes existing row(s) corresponding to the input feature. |
fme_db_ |
The feature operation will be determined by the attribute fme_db_operation on each input feature. A Record ID Attribute containing a valid record ID must be specified in the Row Selection group. The value of fme_db_operation will be processed according to the steps below. Note The processing steps listed below depend on a format's available Feature Operation options.
Same as Insert. | Same as Insert. |
Row Selection
Record ID Attribute
Specify an attribute on the incoming features which will contain record IDs. Record IDs should correspond to valid records in the table; otherwise, this could cause the translation to fail.
The default value for this parameter is the airtable_record_id attribute, which is automatically generated on features output from the Airtable Reader.
Table Options
Let Server Cast Values
Whether to rely on Airtable for attribute value casting and validation.
Yes – Airtable will attempt to cast attribute values which do not match field constraints. Enabling this option may not preserve data integrity.
No (default) – The Airtable Writer will perform client-side validation of input feature values. If a value is invalid, then the feature will be skipped and a warning will be logged.
If a write fails due to an invalid feature value, then the translation will terminate.
Example Value |
Server Field Type |
Server Casts Values set to Yes |
Server Casts Values set to No |
2021-01–01T02:23:30.000Z |
date |
This value is accepted and only the date 2021-01-01. |
The value is rejected (this is a datetime value, not a date), and the feature will be rejected and skipped. |
1234 |
date |
This value is rejected and the translation terminates. |
The value is rejected, and the feature will be rejected and skipped. |
d |
singleSelect (with valid choices [‘a’,’b’,’c’] |
The value is accepted and ‘d’ is added as a list of valid options to the singleSelect field. |
Remove Mentions
Whether to convert mention tokens to plaintext. Airtable supports the usage of mention tokens in multilineText and richText fields which allow collaborators to be tagged. Mention tokens can only be created through the Airtable web GUI and are only valid for the record they are created in.
Yes (default) – The username will be extracted from mention tokens, allowing mention tokens created in other records to be written as plaintext in other records.
No – Mention tokens will be preserved, but they must be written to the record in which they originated (either in a Replace or Update feature operation).
on a feature type in the
