Airtable Format Attributes (Feature Representation)
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
Attribute Name |
Contents |
airtable_type |
The type of geometry represented in the feature. Airtable is a non-spatial format, so the only value is airtable_none. |
airtable_base_id |
The id of the base in which the record was contained. |
airtable_base_name |
The name of the base in which the record was contained. |
airtable_table_id |
The id of the table in which the record was contained. |
airtable_table_name |
The name of the table in which the record was contained. |
airtable_table_description |
The user-defined description of the airtable table to which the record belongs. |
airtable_field_descriptions |
A JSON containing descriptions for fields in the table and their user-defined descriptions. Only fields in the table which have a description defined will be included. |
airtable_view_id |
If the feature type corresponds to a view, this attribute contains the view id. Otherwise, it is empty. |
airtable_view_name |
If the feature type corresponds to a view, this attribute contains the name of the view. Otherwise, it is empty. |
airtable_view_type |
If the feature type corresponds to a view, this attribute contains the type of the view. Otherwise, it is empty. Values are view types supported by Airtable, including [grid, form, calendar, gallery, kanban]. |
airtable_record_creation_time |
An ISO formatted datetime string with the time the record was created. |
airtable_record_json |
A JSON containing the raw data with all the requested fields in the record. This can be used to retrieve additional data for attachment or collaborator fields in the record. |
airtable_record_id |
The ID of the record in Airtable. This attribute can be used to update/delete/replace records when used with the Airtable Writer. This format attribute is exposed by default on features output from the Airtable Reader. |
