OracleSpatial Object: Add Database Connection
To define a new connection from the Connection parameter in an Oracle Spatial or Non-Spatial format:
  • Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Note  To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections
Database Connection
Oracle
Name
Enter a name for the new connection.
Connection Parameters
