Oracle Spatial Relational Reader/Writer
FME can read and write geometric and attribute data stored using Oracle Spatial.
This module communicates directly with Oracle Spatial for maximum throughput. FME supports both the relational and object-relational models of Oracle Spatial: the relational model is discussed here, and the object-relational model is discussed in Oracle Spatial Object Reader/Writer.
Note  If only attributes are to be read or written, use the Oracle Non-Spatial Reader/Writer.
This chapter assumes familiarity with Oracle Spatial and its indexing mechanisms.
Tip  The FeatureReader transformer performs queries against any FME-supported format.
Oracle Spatial Relational Product and System Requirements
Compatibility  Oracle libraries are not yet available for the macOS M1 ARM architecture (Apple Silicon). Please use an alternative platform such as Intel macOS.
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Writer
Yes
Yes
Yes
Yes
- Linux Intel: Yes
- Linux ARM: Yes
- macOS Intel: Yes
- macOS ARM: No
Reader Overview
This reader reads relational tables from Oracle Spatial Relational databases.
Writer Overview
The Oracle Spatial Relational writer module stores both geometry and attributes into an Oracle Spatial database. Only uppercase table names are supported.
