Oracle Non-Spatial Reader Parameters
About Database Connections
Database formats include a Database Connection parameter that defines and stores authentication information. For general information about sharing database connections, please see Using Database Connections. Using Database Connections.
Note that Database Connection parameters differ slightly, depending on context and/or database format.
Connection
From the Connection parameter in a database format, you can do one of the following:
  • Select an existing, previously defined connection. See the section Reusing a Database Connection in Using Database Connections
  • Select Add Database Connection to define a new connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections. The new connection can be made visible only to the current user, or can be shared among multiple users.
Database Connection
Select an existing Oracle database connection, or Add Database Connection...
Add Oracle Database Connection
To define a new connection from the Connection parameter in an Oracle Non-Spatial format, see the topic Oracle Non-Spatial: Add Database Connection
Constraints
Additional Attributes to Expose
Use this parameter to expose Format Attributes in FME Workbench when you create a workspace:
  • In a dynamic scenario, it means these attributes can be passed to the output dataset at runtime.
  • In a non-dynamic scenario, this parameter allows you to expose additional attributes on multiple feature types. Click the browse button to view the available format attributes (which are different for each format) for the reader.
Advanced
