| FME Format Type Identifier | MSACCESS_JDBC_2 |
| Reader/Writer | Both |
| Format Type | Database |
| Typical File Extensions | .mdb, .accdb |
FME can read and write attribute data held in Microsoft Access database tables.
Microsoft Access (JDBC) Product and System Requirements
| Format | FME Platform | Operating System | ||||
| Reader/Writer | FME Form | FME Flow | FME Flow Hosted | Windows 64-bit | Linux | Mac |
| Reader | Yes | Yes | Yes | Yes | Yes | Yes |
| Writer | Yes | Yes | Yes | Yes | Yes | Yes |
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
 FME_JVM_MIN_HEAP_SIZE
                                                Initial heap size for initializing the JVM. If unset, the default value is 1024K.
This variable must be set in multiples of 1024 and greater than 1 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
6291456
6144k
6m
 FME_JVM_MAX_HEAP_SIZE
                                                Maximum heap size for initializing the JVM. If unset, the default value is 16384K.
This variable must be set in multiples of 1024 and greater than 2 MB. To indicate kilobytes, megabytes, or gigabytes, append k or K, m or M, or g or G, respectively. For example, any of these values is acceptable:
83886080
81920k
80m
FME Workbench Reader Overview
Click the Reader Parameters button and establish a Microsoft Access database connection.
FME Workbench Writer Overview
Click the Writer Parameters button and establish a Microsoft Access database connection.
The Microsoft SQL Server writer module stores attribute records into a live relational database. The Microsoft SQL Server writer provides the following capabilities:
- Transaction Support: The Microsoft SQL Server writer provides transaction support that eases the data loading process. Occasionally, a data load operation terminates prematurely due to data difficulties. The transaction support provides a mechanism for reloading corrected data without data loss or duplication.
- Table Creation: The Microsoft SQL Server writer uses the information within the workspace to automatically create database tables as needed.
