Bentley MicroStation Design Reader Feature Type Parameters
These parameters apply only to a selected feature type, not to the entire reader.
Important  If a feature type parameter corresponds to a reader-level parameter, then the reader parameter will be ignored and the feature type parameter will be used.
In V8, the feature type is always taken as the Level Name.
