Attribute Lists – string linkage
If the linkage is of type string, then these attribute list item names are used to specify the values for the string linkage:
Linkage Parameter |
Contents |
stringId |
The key or identifier of the string linkage. This is application-specific, but required on write. Range: Unsigned 32-bit integer Default: No default |
string |
The text data of the string linkage, in system encoding. Range: Any string Default: No default |
