Attribute Lists – incosada linkage
If the linkage is an incosada type, then the following attribute names are added by the reader to hold the values for the British Columbia Forestry File (INCOSADA) linkage.
Linkage Parameter |
Contents |
incosada_fid |
The unique feature ID of the linkage. Range: Character string of size 32 consisting of hex digits |
incosada_sequence_num |
Sequence number of the linkage. Range: Integer |
incosada_feature_code |
The feature code of the INCOSADA feature Range: Unsigned 32-bit integer |
