Industry Foundation Classes (IFC) Supported Element Types
This section provides an overview of the IFC elements currently supported by the IFC_API reader/writer.
Quick Links
Supported Element Types |
Element Types
Actor
The Actor feature type represents IfcActor elements in the dataset. It has the following unique attributes:
Attribute/Trait Name |
Contents |
ifc_actor_type |
Type of Actor. The possible types are:
AirTerminal
The AirTerminal feature type represents IfcAirTerminal elements in the dataset. It has the following unique attributes:
Contents |
ifc_predefined_type |
Type of AirTerminal. The possible types are:
AirTerminalBox
The AirTerminalBox feature type represents IfcAirTerminalBox elements in the dataset. It has the following unique attributes:
Contents |
Type of AirTerminalBox. The possible types are:
Alignment
The Alignment feature type represents IfcAlignment elements in the dataset. It has the following unique attributes:
Contents |
Type of Alignment. The possible types are:
Alignment Cant
The Alignment Cant feature type represents IfcAlignmentCant elements in the dataset. It has the following unique attributes:
Contents |
ifc_rail_head_distance |
Distance between the nominal center points of the two contact patches of wheel set and rails. |
Alignment Horizontal
The Alignment Horizontal feature type represents IfcAlignmentHorizontal elements in the dataset. It does not have any unique attributes.
Alignment Segment
The Alignment Segment feature type represents IfcAlignmentSegment elements in the dataset. It has the following unique attributes:
Contents |
ifc_segment_type |
The type of Alignment Segment, which could be ifcalignmentcantsegment, ifcalignmenthorizontalsegment, or ifcalignmentverticalsegment. Note Some attributes in the table are dependent on the selected segment type. The attributes displayed will vary based on the specific alignment segment.
ifc_start_dist_along |
Distance along the horizontal alignment. Note Displayed only when segment type is ifcalignmentverticalsegment and ifcalignmentcantsegment.
ifc_horizontal_length |
Total length of the segment. Note Displayed only when segment type is ifcalignmentverticalsegment and ifcalignmentcantsegment.
ifc_start_cant_left |
Length of left cant at the beginning of the segment. Note Displayed only when segment type is ifcalignmentcantsegment.
ifc_end_cant_left |
Length of left cant at the end of the segment. Note Displayed only when segment type is ifcalignmentcantsegment.
ifc_start_cant_right |
Length of the right cant at the start of the segment. Note Displayed only when segment type is ifcalignmentcantsegment.
ifc_end_cant_right |
Length of the right cant at the end of the segment. Note Displayed only when segment type is ifcalignmentcantsegment.
ifc_start_point.x |
The x-coordinate of the start point of the segment. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_start_point.y |
The y-coordinate of the start point of the segment. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_start_direction |
Direction of the tangent at the start point of the alignment segment. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_start_radius_of_curvature |
Radius of the curvature at the start point of the segment. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_segment_length |
Total length of the segment along the curve. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_gravity_center_line_height |
Height of the gravity center line in the vertical direction. Note Displayed only when segment type is ifcalignmenthorizontalsegment.
ifc_start_height |
Elevation of the start point. Note Displayed only when segment type is ifcalignmentverticalsegment.
ifc_start_gradient |
Gradient of the alignment segment at the start point. Note Displayed only when segment type is ifcalignmentverticalsegment.
ifc_end_gradient |
Gradient of the alignment segment at the end point. Note Displayed only when segment type is ifcalignmentverticalsegment.
ifc_radius_of_curvature |
Radius of the curvature for the segment. Note Displayed only when segment type is ifcalignmentverticalsegment.
Type of selected Alignment Segment. The possible types are: ifcalignmentcantsegment
Note Displayed for all segment types.
ifc_start_tag |
Tag to annotate the start point of the alignment segment. |
ifc_end_tag |
Tag to annotate the end point of the alignment segment. |
Alignment Vertical
The Alignment Vertical feature type represents IfcAlignmentVertical elements in the dataset. It does not have any unique attributes.
Annotation
The Annotation feature type represents IfcAnnotation elements in the dataset. It has the following unique attributes:
Contents |
Type of Annotation. The possible types are:
AudioVisualAppliance
The AudioVisualAppliance feature type represents IfcAudioVisualAppliance elements in the dataset. It has the following unique attributes:
Contents |
Type of AudioVisualAppliance. The possible types are:
Beam
The Beam feature type represents IfcBeam elements in the dataset. It has the following unique attributes:
Contents |
Type of Beam. The possible types are:
Bearing
The Bearing feature type represents IfcBearing elements in the dataset. It has the following unique attributes:
Contents |
Type of Bearing. The possible types are:
The Bridge feature type represents IfcBridge elements in the dataset. It has the following unique attributes:
Contents |
Type of Bridge. The possible types are:
The BridgePart feature type represents IfcBridgePart elements in the dataset. It has the following unique attributes:
Contents |
Type of BridgePart. The possible types are:
Building
The Building feature type represents IfcBuilding elements in the dataset.
Contents |
ifc_elevation_of_ref_height |
The value of the building’s ElevationOfRefHeight property. Note This property is deprecated in IFC 4x3 and will be dropped when writing to that schema.
ifc_elevation_of_terrain |
The value of the building’s ElevationOfTerrain property. Note This property is deprecated in IFC 4x3 and will be dropped when writing to that schema.
BuildingAddress |
The value of the building’s BuildingAddress property. This attribute will be read as an address, with several BuildingAddress.* sub-attributes. Note This property has been deprecated in IFC 4x3. When writing to IFC 4x3, this attribute will be written as the Pset_Address.
Building Element Part
The Building Element Part feature type represents IfcBuildingElementPart elements in the dataset. It has the following unique attributes:
Contents |
Type of Building Element Part. The possible types are:
Building Element Proxy
The Building Element Proxy feature type represents IfcBuildingElementProxy elements in the dataset. It has the following unique attributes:
Contents |
Type of Building Element Proxy. The possible types are:
Building Storey
The Building Storey feature type represents IfcBuildingStorey elements in the dataset. It has the following unique attributes:
Contents |
ifc_elevation |
Represents the vertical position of the storey's base relative to the building’s internal 0.00 reference level. |
BuildingSystem
The BuildingSystem feature type represents IfcBuildingSystem elements in the dataset. It has the following unique attributes:
Contents |
Type of BuildingSystem. The possible types are:
ifc_longname |
Long name of BuildingSystem. |
BuiltElement
The BuiltElement feature type represents IfcBuiltElement elements in the dataset. Prior to IFC4x3, this was referred to as IfcBuildingElement and uninstantiable. In IFC4x3, this type is instantiable and has no unique attributes.
BuiltSystem
The BuiltSystem feature type represents IfcBuiltSystem elements in the dataset. It has the following unique attributes:
Contents |
Type of BuiltSystem. The possible types are:
ifc_longname |
Long name of BuiltSystem. |
CableCarrierFitting
The CableCarrierFitting feature type represents IfcCableCarrierFitting elements in the dataset. It has the following unique attributes:
Contents |
Type of CableCarrierFitting. The possible types are:
CableCarrierSegment
The CableCarrierSegment feature type represents IfcCableCarrierSegment elements in the dataset. It has the following unique attributes:
Contents |
Type of CableCarrierSegment. The possible types are:
CableFitting
The CableFitting feature type represents IfcCableFitting elements in the dataset. It has the following unique attributes:
Contents |
Type of CableFitting. The possible types are:
CableSegment
The CableSegment feature type represents IfcCableSegment elements in the dataset. It has the following unique attributes:
Contents |
Type of CableSegment. The possible types are:
Chimney
The Chimney feature type represents IfcChimney elements in the dataset. It has the following unique attributes:
Contents |
Type of Chimney. The possible types are:
Column
The Column feature type represents IfcColumn elements in the dataset. It has the following unique attributes:
Contents |
Type of Column. The possible types are:
CommunicationsAppliance
The CommunicationsAppliance feature type represents IfcCommunicationsAppliance elements in the dataset. It has the following unique attributes:
Contents |
Type of CommunicationsAppliance. The possible types are:
Compressor
The Compressor feature type represents IfcCompressor elements in the dataset. It has the following unique attributes:
Contents |
Type of Compressor. The possible types are:
ConveyorSegment
The ConveyorSegment feature type represents IfcConveyorSegment elements in the dataset. It has the following unique attributes:
Contents |
Type of ConveyorSegment. The possible types are:
Course
The Course feature type represents IfcCourse elements in the dataset. It has the following unique attributes:
Contents |
Type of Course. The possible types are:
Covering
The Covering feature type represents IfcCovering elements in the dataset. It has the following unique attributes:
Contents |
Type of Covering. The possible types are:
Curtain Wall
The Curtain Wall feature type represents IfcCurtainWall elements in the dataset. It has the following unique attributes:
Contents |
Type of Curtain Wall. The possible types are :
Damper
The Damper feature type represents IfcDamper elements in the dataset. It has the following unique attributes:
Contents |
Type of Damper. The possible types are :
Deep Foundation
The Deep Foundation feature type represents IfcDeepFoundation elements in the dataset. It does not have any unique attributes.
DistributionBoard
The DistributionBoard feature type represents IfcDistributionBoard elements in the dataset. It has the following unique attributes:
Contents |
Type of DistributionBoard. The possible types are:
DistributionChamberElement
The DistributionChamberElement feature type represents IfcDistributionChamberElement elements in the dataset. It has the following unique attributes:
Contents |
Type of DistributionChamberElement. The possible types are:
DistributionFlowElement
The DistributionFlowElement feature type represents IfcDistributionFlowElement elements in the dataset.
DistributionPort
The DistributionPort feature type represents IfcDistributionPort elements in the dataset. It has the following unique attributes:
Contents |
ifc_flow_direction |
Type of FlowDirection. The possible types are:
Type of DistributionPort. The possible types are:
ifc_system_type |
Type of DistributionSystem. The possible types are:
DistributionSystem
The DistributionSystem feature type represents IfcDistributionSystem elements in the dataset. It has the following unique attributes:
Contents |
ifc_longname |
Long name of DistributionSystem. |
Door
The Door feature type represents IfcDoor elements in the dataset. It has the following unique attributes:
Contents |
ifc_overall_height |
Height of the door. |
ifc_overall_width |
Width of the door. |
Type of Door. The possible types are:
ifc_operation_type |
Defines the general layout and operation of the door type, including the partitioning of panels and the respective panel operations.
ifc_user_defined_operation_type |
Specifies the designator for a user-defined operation type. |
DuctFitting
The DuctFitting feature type represents IfcDuctFitting elements in the dataset. It has the following unique attributes:
Contents |
Type of DuctFitting. The possible types are:
DuctSegment
The DuctSegment feature type represents IfcDuctSegment elements in the dataset. It has the following unique attributes:
Contents |
Type of DuctSegment. The possible types are:
DuctSilencer
The DuctSilencer feature type represents IfcDuctSilencer elements in the dataset. It has the following unique attributes:
Contents |
Type of DuctSilencer. The possible types are:
ElectricAppliance
The ElectricAppliance feature type represents IfcElectricAppliance elements in the dataset. It has the following unique attributes:
Contents |
Type of ElectricAppliance. The possible types are:
ElectricDistributionBoard
The ElectricDistributionBoard feature type represents IfcElectricDistributionBoard elements in the dataset. It has the following unique attributes:
Contents |
Type of ElectricDistributionBoard. The possible types are:
ElectricFlowTreatmentDevice
The ElectricFlowTreatmentDevice feature type represents IfcElectricFlowTreatmentDevice elements in the dataset. It has the following unique attributes:
Contents |
Type of ElectricFlowTreatmentDevice. The possible types are:
ElectricTimeControl
The ElectricTimeControl feature type represents IfcElectricTimeControl elements in the dataset. It has the following unique attributes:
Contents |
Type of ElectricTimeControl. The possible types are:
The FacilityPartCommon feature type represents FacilityPartCommon elements in the dataset. It has the following unique attributes:
Contents |
Type of FacilityPartCommon. The possible types are:
Fan
The Fan feature type represents IfcFan elements in the dataset. It has the following unique attributes:
Contents |
Type of Fan. The possible types are:
The Filter feature type represents IfcFilter elements in the dataset. It has the following unique attributes:
Contents |
Type of Filter. The possible types are:
FireSuppressionTerminal
The FireSuppressionTerminal feature type represents IfcFireSuppressionTerminal elements in the dataset. It has the following unique attributes:
Contents |
Type of FireSuppressionTerminal. The possible types are:
FlowMeter
The FlowMeter feature type represents IfcFlowMeter elements in the dataset. It has the following unique attributes:
Contents |
Type of FlowMeter. The possible types are:
Footing
The Footing feature type represents IfcFooting elements in the dataset. It has the following unique attributes:
Contents |
Type of Footing. The possible types are:
GeographicElement
The GeographicElement feature type represents IfcGeographicElement elements in the dataset. It has the following unique attributes:
Contents |
Type of GeographicElement. The possible types are:
Interceptor
The Interceptor feature type represents IfcInterceptor elements in the dataset. It has the following unique attributes:
Contents |
Type of Interceptor. The possible types are:
JunctionBox
The JunctionBox feature type represents IfcJunctionBox elements in the dataset. It has the following unique attributes:
Contents |
Type of JunctionBox. The possible types are:
Kerb
The Kerb feature type represents IfcKerb elements in the dataset. It has the following unique attributes:
Contents |
Type of Kerb. The possible types are:
Lamp
The Lamp feature type represents IfcLamp elements in the dataset. It has the following unique attributes:
Contents |
Type of Lamp. The possible types are:
LightFixture
The LightFixture feature type represents IfcLightFixture elements in the dataset. It has the following unique attributes:
Contents |
Type of LightFixture. The possible types are:
LiquidTerminal
The LiquidTerminal feature type represents IfcLiquidTerminal elements in the dataset. It has the following unique attributes:
Contents |
Type of LiquidTerminal. The possible types are:
The MarineFacility feature type represents MarineFacility elements in the dataset. It has the following unique attributes:
Contents |
Type of MarineFacility. The possible types are:
The MarinePart feature type represents MarinePart elements in the dataset. It has the following unique attributes:
Contents |
Type of MarinePart. The possible types are:
MedicalDevice
The MedicalDevice feature type represents IfcMedicalDevice elements in the dataset. It has the following unique attributes:
Contents |
Type of MedicalDevice. The possible types are:
Member
The Member feature type represents IfcMember elements in the dataset. It has the following unique attributes:
Contents |
Type of Member. The possible types are:
MobileTelecommunicationsAppliance
The MobileTelecommunicationsAppliance feature type represents IfcMobileTelecommunicationsAppliance elements in the dataset. It has the following unique attributes:
Contents |
Type of MobileTelecommunicationsAppliance. The possible types are:
OpeningElement
The OpeningElement feature type represents IfcOpeningElement elements in the dataset. It has the following unique attributes:
Contents |
Type of OpeningElement. The possible types are:
The OpeningElement feature type is always written to “Body” Geometric Representation Type.
Outlet
The Outlet feature type represents IfcOutlet elements in the dataset. It has the following unique attributes:
Contents |
Type of Outlet. The possible types are:
PipeFitting
The PipeFitting feature type represents IfcPipeFitting elements in the dataset. It has the following unique attributes:
Contents |
Type of PipeFitting. The possible types are:
PipeSegment
The PipeSegment feature type represents IfcPipeSegment elements in the dataset. It has the following unique attributes:
Contents |
Type of PipeSegment. The possible types are:
Plate
The Plate feature type represents IfcPlate elements in the dataset. It has the following unique attributes:
Contents |
Type of Plate. The possible types are:
ProtectiveDevice
The ProtectiveDevice feature type represents IfcProtectiveDevice elements in the dataset. It has the following unique attributes:
Contents |
Type of ProtectiveDevice. The possible types are:
Pump
The Pump feature type represents IfcPump elements in the dataset. It has the following unique attributes:
Contents |
Type of Pump. The possible types are:
Rail
The Rail feature type represents IfcRail elements in the dataset. It has the following unique attributes:
Contents |
Type of Rail. The possible types are:
Railing
The Railing feature type represents IfcRailing elements in the dataset. It has the following unique attributes:
Contents |
Type of Railing. The possible types are:
The Railway feature type represents IfcRailway elements in the dataset. It has the following unique attributes:
Contents |
Type of Railway. The possible types are:
The RailwayPart feature type represents IfcRailwayPart elements in the dataset. It has the following unique attributes:
Contents |
Type of RailwayPart. The possible types are:
Ramp
The Ramp feature type represents IfcRamp elements in the dataset. It has the following unique attributes:
Contents |
Type of Ramp. The possible types are:
Ramp Flight
The Ramp Flight feature type represents IfcRampFlight elements in the dataset. It has the following unique attributes:
Contents |
Type of Ramp Flight. The possible types are:
The Road feature type represents IfcRoad elements in the dataset. It has the following unique attributes:
Contents |
Type of Road. The possible types are:
The RoadPart feature type represents IfcRoadPart elements in the dataset. It has the following unique attributes:
Contents |
Type of RoadPart. The possible types are:
Roof
The Roof feature type represents IfcRoof elements in the dataset. It has the following unique attributes:
Contents |
Type of Roof. The possible types are:
SanitaryTerminal
The SanitaryTerminal feature type represents IfcSanitaryTerminal elements in the dataset. It has the following unique attributes:
Contents |
Type of SanitaryTerminal. The possible types are:
Signal
The Signal feature type represents IfcSignal elements in the dataset. It has the following unique attributes:
Contents |
Type of Signal. The possible types are:
Site
The Site feature type represents IfcSite elements in the dataset. It has the following unique attributes:
Contents |
ifc_ref_latitude |
Specifies the world latitude at the reference point. |
ifc_ref_longitude |
Specifies the world longitude at the reference point. |
ifc_ref_elevation |
Represents the datum elevation relative to sea level. |
ifc_land_title_number |
Specifies Land title number. Note This property has been deprecated in IFC 4x3. When writing to IFC 4x3, this attribute will be written as the Pset_LandRegistration.
SiteAddress |
The value of the building’s SiteAddress property. This attribute will be read as an address, with several SiteAddress.* sub-attributes. Note This property has been deprecated in IFC 4x3. When writing to IFC 4x3, this attribute will be written as the Pset_Address.
Slab
The Slab feature type represents IfcSlab elements in the dataset. It has the following unique attributes:
Contents |
Type of Slab. The possible types are:
Space
The Space feature type represents IfcSpace elements in the dataset. It has the following unique attributes:
Contents |
Type of Space. The possible types are:
ifc_elevation_with_flooring |
Level of flooring of the space. |
SpaceHeater
The SpaceHeater feature type represents IfcSpaceHeater elements in the dataset. It has the following unique attributes:
Contents |
Type of SpaceHeater. The possible types are:
StackTerminal
The StackTerminal feature type represents IfcStackTerminal elements in the dataset. It has the following unique attributes:
Contents |
Type of StackTerminal. The possible types are:
Stair
The Stair feature type represents IfcStair elements in the dataset. It has the following unique attributes:
Contents |
Type of Stair. The possible types are:
Stair Flight
The Stair Flight feature type represents IfcStairFlight elements in the dataset. It has the following unique attributes:
Contents |
ifc_number_of_risers |
Number of Risers. Note This property has been deprecated in IFC 4 and above. When writing, this attribute will be written as the Pset_StairFlightCommon.NumberOfRisers.
ifc_number_of_treads |
Number of Treads. Note This property has been deprecated in IFC 4 and above. When writing, this attribute will be written as the Pset_StairFlightCommon.NumberOfTreads.
ifc_riser_height |
Riser height. Note This property has been deprecated in IFC 4 and above. When writing, this attribute will be written as the Pset_StairFlightCommon.RiserHeight.
ifc_tread_length |
Tread length. Note This property has been deprecated in IFC 4 and above. When writing, this attribute will be written as the Pset_StairFlightCommon.TreadLength.
Type of Stair Flight. The possible types are:
StructuralAnalysisModel
The StructuralAnalysisModel feature type represents IfcStructuralAnalysisModel elements in the dataset. It has the following unique attributes:
Contents |
Type of StructuralAnalysisModel. The possible types are:
SwitchingDevice
The SwitchingDevice feature type represents IfcSwitchingDevice elements in the dataset. It has the following unique attributes:
Contents |
Type of SwitchingDevice. The possible types are:
Valve
The Valve feature type represents IfcValve elements in the dataset. It has the following unique attributes:
Contents |
Type of Valve. The possible types are:
WasteTerminal
The WasteTerminal feature type represents IfcWasteTerminal elements in the dataset. It has the following unique attributes:
Contents |
Type of WasteTerminal. The possible types are:
Window
The Window feature type represents IfcWindow elements in the dataset. It has the following unique attributes:
Contents |
Height of the window. |
ifc_overall_width |
Width of the window. |
ifc_partitioning_type |
Layout type of the window in terms of partitioning of panels. The possible types are:
Type of Window. The possible types are:
ifc_related_opening_element_id |
Global Id of the Opening related to the window. |
Zone
The Zone feature type represents IfcZone elements in the dataset. It has the following unique attributes:
Contents |
ifc_longname |
Long name of Zone. |
