GeoParquet User Attributes
Readers: For information on the parameters in this dialog that are common to all readers, see:
Writers: For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name is the name of the attribute to be written.
Type
Description
boolean
Represents true/false data.
binary
Represents variable-length binary data.
bson
Represents an embedded BSON document.
date
Represents date data.
decimal
Represents fixed width signed decimal data. Width must be a non-zero positive integer. Precision must be a positive integer less than width or default 0. The maximum supported width is 38.
double
Represents 64-bit floating precision numbers.
enum
Represents enumerated type values.
float
Represents 32-bit floating precision numbers.
geometry
Represents spatial data. The writer will create a geometry column with the provided name. Otherwise, geometry columns will be determined based on the first feature, defaulting to GEOM.
int8
Represents 8-bit signed integers.
int16
Represents 16-bit signed integers.
int32
Represents 32-bit signed integers.
int64
Represents 64-bit signed integers.
interval
Represents an interval of time as a number of months, days, and milliseconds independent of any timezone or date.
json
Represents an embedded JSON document.
string
Represents variable length UTF-8 encoded character strings.
time32
Represents time data that is adjusted to UTC with millisecond precision.
time64
Represents time data that is adjusted to UTC with nanosecond precision.
time_micro
Represents time data that is adjusted to UTC with microsecond precision.
time_micro_local Represents time data with microsecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
time_milli
time_milli_local Represents time data with millisecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
time_nano
time_nano_local Represents time data with nanosecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
timestamp
Represents a moment in time that is adjusted to UTC with nanosecond precision. The supported timestamp range with this precision is between 1677-09-21 00:12:43 and 2262-04-11 23:47:16.
timestamp_micro
Represents a moment in time that is adjusted to UTC with microsecond precision.
timestamp_micro_local Represents a moment in time with microsecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
timestamp_milli
Represents a moment in time that is adjusted to UTC with millisecond precision.
timestamp_milli_local Represents a moment in time with millisecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
timestamp_nano
timestamp_nano_local Represents a moment in time with nanosecond precision. Values are independent of timezone and will read as written regardless of system time zone settings.
uint8
Represents 8-bit unsigned integers.
uint16
Represents 16-bit unsigned integers.
uint32
Represents 32-bit unsigned integers.
uint64
Represents 64-bit unsigned integers.
uuid
Represents a universally unique identifier. The attribute value must be valid UUID. For example: 00112233-4455-6677-8899-aabbccddeeff
x,y,z-coordinate
Coordinate fields store 64-bit floating point values used to create the x, y, and (optionally) z coordinates of a point geometry for the row. The point geometry will be created in addition to the attributes of coordinate types.
Only relevant for Reader if the file is not already spatial.
