FME Augmented Reality (FME AR) Writer Parameters
Scaling Parameters
Initial Model Scaling
With compatible versions of the FME Realize mobile app, this parameter controls how the initial presentation of the scene appears.
- Full Scale (default) – When viewed with the FME Realize mobile app, the model will be scaled such that it is displayed in a 1:1 scale. For example, this could be used to render an architectural drawing to provide a virtual 3D walkthrough, preserving distances and object sizes.
- Custom – Enables the Custom Scale parameter, which allows you to specify a custom scale while still preserving relative sizes and distances between objects in the scene.
Custom Scale
Used with Initial Model Scaling: Custom. Custom scale is set as a ratio (for example, 1:10 or 1to10).
