Elastic Elasticsearch Writer Feature Type Parameters
To access feature type parameters, click the gear icon Tip To always display the editor in FME Workbench, you can select View > Windows > Parameter Editor.
General All feature types share similar General parameters, which may include Feature Type Name, Reader or Writer information, and Geometry. In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept Table or Index Qualifier prefixes on the output table feature type. |
Table Settings: General
This parameter specifies how features will be written into the destination table. Supported feature operations are described below. Note that the described behavior can be dependent on the selected options, as well as the underlying table properties.
- More information about Feature Operations.
Option |
Description |
If the Row Does Not Exist |
If the Row Exists |
Upsert |
The writer appends a new row or updates an existing row(s) using input feature attributes and/or geometries. |
The writer creates a new row using input feature attributes and/or geometries. |
The writer changes values of the existing row(s) corresponding to the input feature that differ from the input feature. It leaves other attributes untouched. |
Put |
The writer appends a new row to a table using input feature attributes and/or geometries. If a row with the same primary identifier already exists, the existing row is overwritten by the new row. |
The writer deletes the existing row corresponding to the input feature and appends a new row using input feature attributes and/or geometries. |
fme_db_ |
The feature operation will be determined by the attribute fme_db_operation on each input feature. The value of fme_db_operation will be processed according to the steps below. Note: The processing steps listed below depend on a format's available Feature Operation options.
The action depends on the operation; however, in general, if nothing is specified, the value is treated as an Insert. | The value is treated as an Insert. |
Table Handling
This parameter controls how the feature type handles destination tables. These options are available:
- Create If Needed – Create destination table if it does not exist. The writer uses the information within the FME workspace to automatically create Vector Feature tables as required. All tables will be created when the first input feature is processed. If no features are sent to a feature type, then the corresponding table will not be created.
- Use Existing – If the destination database does not exist, the translation will fail.
Drop and Create (version 7 and later only) – Drop destination table if it exists, then create it. The writer will drop and re-create the table before writing any features to it. Tables will be overwritten when the first input feature is processed. If no features are sent to a feature type, then the corresponding table will not be overwritten.
Mapping Creation Parameters
This parameter is a table of geometry fields to create on the type. Each row in the table represents a geometry field that has a Name and a Type, where the Type can be one of:
- geo_point – Geometry is stored as LonLat coordinate pairs. Non-point geometry will be converted to a centroid point.
- geo_shape – Geometry is stored using the GeoJSON specification, so most vector geometry is supported. However, some Elasticsearch spatial functions do not work on geo_shape fields.
To write to particular geometry fields on an Elasticsearch type, features should use Named Geometry. Otherwise, geometry will only be written if there is exactly one geometry field in the type.
Default:
- Name: geometry
- Type: geo_point
This parameter contains a list of fields to store directly within the index. If a field is included in this list, it means that the field’s value can be accessed more quickly by Elasticsearch. Note, however, that the index will take more space and may be less efficient.
Fields that are not in this list will be stored and indexed normally.
Advanced
The source of JSON documents to write to the database.
- Feature: Documents will be created from features sent to the Elasticsearch writer (which is the usual behavior). This option enables the Document ID Attribute parameter.
- JSON Attribute: Documents will be created using JSON directly from an attribute, if possible. This option enables the Raw JSON Attribute parameter.
This parameter is enabled when the Document Source is Feature. It can be used to specify an attribute to use as the Document ID. Any features that contain that attribute will use its value as the JSON Document ID.
This parameter is enabled when the Document Source is JSON Attribute. It can be used to specify an attribute to use directly as the document JSON. Any features that contain the JSON attribute will be written using the JSON attribute value. Other features will be written normally.
