IBM DB2 (JDBC) Reader/Writer
FME can access attribute data held in IBM DB2 database tables.
FME provides read and write access via IBM’s DB2 JDBC driver, which is bundled with FME.
Note  For FME 2025.0, we have improved the user experience by combining spatial and non-spatial formats. Previous format identifier:
  • IBM DB2 Non-Spatial (JDBC): DB2_JDBC_NONSPATIAL
Product and System Requirements
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
No
Yes
Yes
Yes
Writer
Yes
Yes
No
Yes
Yes
Yes
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
Tip  To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Memory Usage (applicable to writers only): Changing the value in the writer parameter Features Per Transaction can control the number of features that FME places in each transaction before a transaction is committed to the database.
