Databricks Reader
FME can read attribute data held in Databricks database tables.
FME provides read access via Databricks’s JDBC driver, which is bundled with FME.
Databricks Product and System Requirements
Format
FME Platform
Operating System
Reader/Writer
FME Form
FME Flow
FME Flow Hosted
Windows 64-bit
Linux
Mac
Reader
Yes
Yes
Yes
Yes
Yes
Yes
Writer
See Databricks Writer (FME Form Package)
Getting Started with Databricks
This tutorial series details how to use the Databricks reader and writer, including creating database connections and example scenarios.
See the FME Knowledge Base article Getting Started with Databricks.
The performance of this format is dependent on the amount of memory allocated to the Java Virtual Machine (JVM). The following environment variables allow you to specify memory available to Java Plugins:
Tip  To pass additional parameters used by FME to the Java Virtual Machine, use the JAVA_TOOL_OPTIONS environment variable.
Memory Usage (applicable to writers only): Changing the value in the writer parameter Features Per Transaction can control the number of features that FME places in each transaction before a transaction is committed to the database.
