Databricks (JDBC): Add Database Connection
To define a new connection from the Connection parameter in a Databricks format:
  • Select Add Database Connection. See database-specific parameters below, as well as the section Adding a Database Connection in a Workspace in Using Database Connections The new connection can be made visible only to the current user, or can be shared among multiple users.
Note  To select an existing, previously defined connection, see the section Reusing a Database Connection in Using Database Connections.
Database Connection
Databricks
Name
Enter a name for the new connection.
Connection Parameters
Server Hostname
The server hostname of your Databricks cluster.
HTTP Path
The HTTP path of your Databricks cluster.
Authentication
The method used for authentication. Each method enables different parameter options.
Note  Databricks stopped supporting Databricks-managed passwords as of July 10, 2024. OAuth authentication as well as personal access token authentication are the preferred methods for authentication.
Personal Access Token
Connects using a personal access token from Databricks.
The personal access token to connect to the specified cluster. This parameter is enabled when you select the Personal Access Token authentication method.
OAuth (Web Connection)
Uses an OAuth web connection that accesses the Databricks service. This option enables the Databricks OAuth Connection parameter, from which you can pick a saved connection, or add a Databricks OAuth Web Connection.
Adding a Databricks OAuth Connection
The OAuth web connection used to connect to the service principal that accesses the specified cluster. These parameters are enabled when you select the OAuth (Web Connection) authentication method and click Add Web Connection:
  • Token Endpoint URL – The URL used to request an OAuth connection token.
  • Client ID – The client ID for the OAuth secret for the service principal.
  • Client Secret – The value of the OAuth secret for the service principal.
  • Scope – The scope of the requested OAuth access token. For Microsoft Azure-hosted Databricks clusters, the scope value must be set to 2ff814a6-3304-4ab8-85cb-cd0e6f879c1d/.default. See Get a Microsoft Entra ID access token with the Microsoft identity platform REST API from the Azure Databricks documentation website for more information on the required scope value.
Adding a Databricks OAuth U2M Connection
The OAuth web connection used to connect to the specified cluster using Authorization Code flow. These parameters are enabled when you select the OAuth (Web Connection) authentication method and click Add Web Connection:
  • Client ID – The client ID for the OAuth request. This value can typically be set to databricks-cli.
  • Client Secret – The value of the OAuth secret for the service principal. This is optional.
  • Redirect URI – The redirect URI for the Authorization Code request. This value is typically set to http://localhost in FME Form and https://<your-fme-flow-url>/fmeoauth in FME Flow. This should match the configuration in Databricks.
  • Workspace URL – The URL of the Databricks workspace. This is typically the same as the Server Hostname in the Connection Parameters.
OAuth U2M
Connects using U2M using the Databricks JDBC driver. The first time you connect, a new browser tab will open to enable you to log in using your credentials.
Token Cache Pass Phrase
The pass phrase used to enable persistent token caching.
Setting a value here will enable the driver to cache the access token for use in subsequent connections, preventing repeated browser pop-ups. This parameter is enabled when you select the OAuth U2M authentication method.
More Information
Authentication Method
M2M OAuth Connections
U2M OAuth connections
OAuth for AWS-hosted Databricks clusters
See Authorize service principal access to Databricks with OAuth on the Databricks documentation website.
See Authorize user access to Databricks with OAuth on the Databricks documentation website.
OAuth for Microsoft Azure-hosted Databricks clusters
See OAuth 2.0 client credentials grant on the Microsoft documentation website.
See Authorize user access to Azure Databricks with OAuth on the Microsoft documentation website.
Catalog
Specifies the default catalog to use once connected. The specified catalog should be an existing catalog.
Note  This parameter is case-sensitive.
