Esri ArcGIS Layer Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
The ArcGIS Layer modules make use of the following special attribute names.
Attribute Name
Contents
geodb_type
The type of geometric entity stored within the feature. The valid values are listed below:
  • geodb_point
  • geodb_multipoint
  • geodb_polyline
  • geodb_arc
  • geodb_ellipse
  • geodb_polygon
  • geodb_annotation
  • geodb_dimension
  • geodb_simple_junction
  • geodb_simple_edge
  • geodb_complex_junction
  • geodb_complex_edge
For a description of the attributes belonging to each geodb_type, please see the chapter Esri Geodatabase Formats.
geodb_feature_is_simple
Indicates whether or not the geometry is simple.
Features read from a dataset also have an attribute for each attribute in the layer/feature class.
