Apache Hive (Hadoop) User Attributes
User attributes for this format are defined below.
Name The name of the field to be written.
Type
This format supports the following field types.
array
Complex type that represents an array.
bigint
Represents 64-bit signed integers.
binary
Represent a binary value.
boolean
Stores the logical values true or false.
char
Represents a fixed-length character string from 1 to 255.
date
Represents date data from January 1, 0001 to December 31, 9999.
See Standard FME Date/Time Format.
decimal
Represents a decimal number with a maximum precision of 38.
double
Represents a 64-bit double-precision floating point number.
float
Represents a 32-bit single-precision floating point number.
int
Represents a 32-bit (4-byte) signed integer.
map
Complex type, represents a map (a dictionary).
smallint
Represents 16-bit (2-byte) signed integer.
string
Represents a character string
struct
Represents a composite data type that contains a collection of other complex and simple data types.
timestamp
This type is used to represent date and time data from January 1, 0001 to December 31, 9999 with optional nanosecond precision.
tinyint
Represents a 8-bit (1-byte) signed integer.
varchar
Represents a variable length character string of length 1 to 65535.
Note  Hive also supports “Union” and “Interval” column types. None of Hive JDBC drivers support the “Union” column type, and “Interval” column types will be read as a string.
