FME Form: 2026.2
About the Reader and Writer Gallery
Utilities > Browse Readers and Writers
The Reader and Writer Gallery lists all formats supported by FME.
The gallery includes the following information:
Column Definition
Description
The full format name as it appears in FME.
Short Name
The FME format abbreviation (also called Format Identifier).
Extensions
The file extension(s) associated with the format.
Type
Format type:
  • Database
  • File
  • Folder
  • None (web connection)
  • URL
Read/Write
Indicates whether the format is a reader, a writer, or both.
Coordinate System
Indicates whether a custom coordinate system is associated with the format.
Licensed
Indicates whether FME is licensed to read/write the format.
Search
Enter a keyword or a partial text string to filter results.
Custom Formats
  • Create a new format using the Custom Format wizard.
  • Import a custom format and add it to the gallery.
  • Edit or delete an existing custom format.
The following icons identify Custom Formats in the gallery:
Icon Description
Custom Format created by the user or included with an FME installation.
Custom formats and format packages downloaded and installed from FME Hub.
Close
Close the gallery.
Quick Facts
Click on a format, then click Quick Facts to display the technical documentation for the format.
