FME Form: 2026.1
Updating Feature Types
If the structure of the data changes in your workspace (for example, the schema changes or an attribute type changes) you will usually want to keep your workspace up-to-date. This is a particularly useful feature if you are working with databases, or if you are sharing data within a workgroup.
Select Build > Readers > Update Feature Types or Build > Writers > Update Feature Types.
