FME Form: 2026.3
Removing Unattached Objects
To quickly remove unattached objects:
  1. Select Run > Remove > Unattached. A list of unattached objects appears.
  2. For large lists, use the search filter to display
  3. Use the checkboxes to delete the selected objects, and click OK.
