FME Form: 2026.3
Oracle Connectivity
Problems sometimes arise when attempting to connect to an Oracle database. This is almost always due to a misconfiguration in the user’s environment. The following suggestions can often help detect and overcome such problems.
- Ensure you can connect to the database with the service name, user name, and password using SQL*Plus.
- Ensure you have a version of the Oracle client software installed that is compatible with your Oracle database.
- If you had older versions of the Oracle client software installed, make sure that your PATH variable has the current version’s Oracle folder first.
- Ensure the Oracle Client is 64-bit, to match the bit architecture of FME.
- If using tnsnames.ora with the Oracle Instant Clients, ensure the TNS_ADMIN environment variable is set and pointing to the folder containing the tnsnames.ora file.
See Also
