FME Form: 2026.3
Filtering Feature Display
In 2D or 3D view mode, you can apply a filter to a view to display only the features you want. With the Filter Features tool, you can create expressions—from simple to highly complex—to define your filtering criteria.
To Apply Filters
  1. Click the Filter tool on the toolbar ,or select Explore > Filter 2D/3D Display from the menu bar.
  2. On the Filter Features dialog, check Enable Filters.
  3. Specify Test Clauses: The filter criteria expressions. The Filter Feature dialog provides a variety of operands for building expressions, along with a set of functions you can perform on feature attributes to further refine your expression.
  1. Click OK.
For a detailed description of the fields in the Filter Features dialog, see Filter Features Dialog.
To Remove Filters
  2. On the Filter Features dialog, uncheck Enable Filters.
  3. Click OK.
Example: Apply a Simple Filter
In the following example applied on a dataset of city parks, a filter is created to prevent golf courses from being displayed in the FME Data Inspector. The filter tests the SpecialFeatures attribute of features in the city_parks feature type to determine if it contains the string "golf." If it does, the feature is filtered out and not displayed.
Example: Create a Filter from a Composite Expression
The following filter displays only parks that are designated for dogs and are located in the West End or Kitsilano neighborhoods.
See Also
