FME Form: 2026.3
FME Flow Parameters
FME Flow parameters reference FME Flow system settings when a workspace is run from FME Flow. These parameters may be useful when testing or debugging a workspace that is going to be run from FME Flow.
If the workspace that is currently open uses any FME Flow parameters, they are listed first in the Navigator. Any other FME Flow parameters that are not referenced in the workspace are listed under Unreferenced. If you have an active connection to FME Flow, the values auto-populate according to that connection.
Parameter Description
FME_DATA_REPOSITORY Name of the folder used by FME Flow for temporarily uploading data.
FME_ENGINE Name of the FME Engine that runs the workspace.
FME_JOB_ID FME Flow job identifier of the job that invokes the workspace.
FME_SECURITY_ROLES Role of the FME Flow user who runs the workspace. For example, fmeadmin and fmeauthor are two common roles.
FME_SECURITY_USER FME Flow user that runs the workspace.
FME_SERVER_DEST_DIR File path where the FME Flow Data Download and Data Streaming services write output data.
FME_SERVER_HOST FME Flow host name used to invoke this workspace.
FME_SERVER_PORT FME Flow port on which the workspace is invoked.
FME_SERVER_REQUEST_HEADERS FME Flow Web Services request header information, which includes the client IP of requests used to invoke the workspace.
FME_SERVER_REQUEST_METHOD HTTP request method used to invoke the workspace. This parameter is set only in workspaces that are run by the FME Flow Data Streaming service.
FME_SERVER_REQUEST_PARAMETERS FME Flow Web Services request query parameters. Includes query parameters passed as part of the URL, as well as query parameters sent through a POST request body of content type "application/x-www-form-urlencoded" and "multipart/form-data".
FME_SERVER_REQUEST_URI FME Flow Web Services URI used to invoke the workspace. This parameter is set only in workspaces that are run by the FME Flow Job Submitter, Data Streaming, or Data Download services.
FME_SERVER_RUNTIME_USER User name of the FME Flow account that authenticated with the FME Flow workspace app to run the workspace.
FME_SERVER_RUNTIME_USER_ID Unique identifier of the FME Flow user account that authenticated with the FME Flow workspace app to run the workspace.
FME_SERVER_WEB_URL Web Application Server root URL that invokes the workspace.
FME_SHAREDRESOURCE_BACKUP FME Flow Resources folder for storing FME Flow backup files.
FME_SHAREDRESOURCE_DASHBOARD FME Flow Resources folder for storing Dashboard reports.
FME_SHAREDRESOURCE_DATA FME Flow Resources folder for storing data files that can be shared between workspaces.
FME_SHAREDRESOURCE_ENGINE FME Flow Resources folder for storing FME Engine resources.
FME_SHAREDRESOURCE_LOG FME Flow Resources folder for storing log files.
FME_SHAREDRESOURCE_SYSTEM FME Flow Resources folder for storing connections to network resources.
FME_SHAREDRESOURCE_TEMP FME Flow Resources folder for storing temporary files created by FME Flow.
FME_TOPIC_MESSAGE Location of the FME Flow Notification Service message. This parameter is set only in workspaces that are run from an FME workspace subscriber. For more information, see FME workspace Subscriber in the FME Flow documentation.
FME_TOPIC FME Flow Notification Service topic that invokes the workspace.
See Also
