FME Flow: 2026.3
Unsupported SASL Mechanism
Log file message:
(Directory Server) SASL mechanism "..." is not supported by Directory Server.
Cause
Authentication Method = SASL is specified for a Authentication Services connection, but the specified SASL mechanism was not supported by the directory server.
Resolution
The SASL field of a directory server connection must be set to an SASL mechanism that is supported by the directory server.
To see the SASL mechanisms supported by a directory server:
From AD Explorer:
- Connect to the Active Directory.
- Right-click the Active Directory root, and select 'Properties...'.
- Select the 'RootDSE Attributes' tab.
- The supported SASL mechanisms for this Active Directory server are listed under the 'supportedSASLMechanisms' attribute.
MSDN:
- Determine the version of Microsoft Windows® Server.
- The supported SASL mechanisms are listed under in this MSDN article: https://docs.microsoft.com/en-us/openspecs/windows_protocols/ms-adts/a98c1f56-8246-4212-8c4e-d92da1a9563b.
