FME Flow: 2026.1
Test the Installation
To test your FME Flow installation, confirm that FME Flow can perform its primary function—running a job.
  1. On the Run Workspace page, specify:
    • Repository: Samples
    • Workspace: austinApartments.fmw
    • Service: Job Submitter
  2. Click Run Workspace.
  3. If you see a success message, your install was a success.
See Also
