FME Flow: 2026.1
Purging Logs and History
As FME Flow processes jobs, the history of these jobs is stored as records in the repository database and as log files in the file system. Eventually, the volume of these records and logs can build up and cause issues, such as slow web interface response time and low disk space.
To purge log files and job history, use the tools on the System Cleanup page of the Web User Interface.
