FME Flow: 2026.3
Install on Windows
To install FME Engine in a Windows environment
On all FME Engine hosts that you want to upgrade:
  1. Create a new directory for the upgraded FME Engine:
    <FMEFlowDir>\Server\FMEEngineUpgrade
    Be sure to leave the existing FME Engine in place as a backup:
    <FMEFlowDir>\Server\fme
  2. Run the FME installer.
  3. When the installer prompts for the Destination Folder, enter the path to the new directory created in step 1.
  4. After the installer finishes successfully, open Windows Explorer.
  5. Make a copy of the file <FMEFlowDir>\Server\FMEEngineUpgrade\fme.exe, place that copy in the same <FMEFlowDir>\Server\FMEEngineUpgrade directory, and rename it FMEEngine.exe.
  6. Edit the processMonitorConfigEngines.txt file:
    Look for lines that start FME Engines, such as the following:
    TEMPLATE_START_ENGINE="C:/Program Files/FMEFlow/Server/fme/FMEEngine.exe"
    and change the path to the new FME, for example:
    TEMPLATE_START_ENGINE="C:/Program Files/FMEFlow/Server/FMEEngineUpgrade/FMEEngine.exe"
    Important  Use forward slashes in the path.
  7. Restart FME Flow.
  8. To confirm that you are using the upgraded FME Engine from the new path and that you are using the FME build that you require, check the process monitor engine log (fmeprocessmonitorengine.log) on any computer running an FME Engine. In the log, you should see your new FME Engine path and build number reflected in the FME Start-up sections.
    Note  Upgraded FME Engines are not reflected on the Engines page unless you perform a Full FME Flow Upgrade.
