FME Flow: 2024.1
Importing a CA Certificate for SSL Connections
To authenticate SSL connections using a CA certificate, import the certificate and instruct FME Flow to add it to the list of trusted certificates.
  1. Make a backup of the current list of trusted Certificate Authorities:
  2. <FMEFlowDir>/Utilities/jre/lib/security/cacerts
  3. Obtain your RootCA certificate as a .cer file:
  4. http://<domain-controller>/certsrv/certcarc.asp > 'install this CA certificate'
    Or, contact your domain administrator
  5. Add the certificate to the list of trusted ones:
    • Linux:
    • Open the command terminal and issue the following commands:
      cd <FMEFlowDir>/Utilities/jre
      ./bin/keytool -import -trustcacerts -alias <rootca-alias> -file <cer-file> -keystore ./lib/security/cacerts
    • Windows:
    • Launch cmd.exe and issue the following commands:
      cd <FMEFlowDir>\Utilities\jre
      bin\keytool -import -trustcacerts -alias <rootca-alias> -file <cer-file> -keystore
      lib\security\cacerts
      When prompted for keystore password, default is changeit.
      When prompted to trust certificate, answer yes.
    Where:
    • <rootca-alias> is the custom alias for the certificate.
    • <cer-file> is the path to the .cer file downloaded in step 2.
  6. Restart FME Flow.
