FME Flow: 2025.2
Importing a CA-Signed Certificate for LDAPS Connections
To authenticate LDAP over SSL (LDAPS) connections using a CA-signed certificate, import the certificate and instruct FME Flow to add it to the list of trusted certificates.
  1. Make a backup of the cacerts file that contains the current list of trusted Certificate Authorities. This file is located in:
  2. <FMEFlowDir>/Utilities/jre/lib/security/cacerts
  3. From your domain administrator, obtain your DC host’s certificate and any intermediary and root CA files in the certificate chain as individual .cer files. You can also use a wildcard certificate instead of the specific DC host’s certificate.
  4. Import the DC server-level certificate to the cacerts keystore file:
    • Linux:
    • Open the command terminal and issue the following commands:
      cd <FMEFlowDir>/Utilities/jre/bin
      keytool -import -trustcacerts -alias <cert-alias> -file <cer-file> -keystore "<FMEFlowDir>/Utilities/jre/lib/security/cacerts"
    • Windows:
    • Launch cmd.exe and issue the following commands:
      cd <FMEFlowDir>\Utilities\jre\bin
      "<FMEFlowDir>\Utilities\jre\lib\security\cacerts"
    When prompted for the keystore password, the default is changeit.
    When prompted to trust the certificate, answer yes.
    Where:
    • <cert-alias> is the custom alias for the certificate, used to identify easily the certificate in the list of certificates. It can be any unique name.
    • <cer-file> is the full path to the .cer files.
    • <FMEFlowDir> is the FME Flow installation directory.
  5. Repeat step 3 for the root and any intermediary certificate, where applicable.
  6. Restart FME Flow.
