FME Flow: 2026.3
Configuring International Character Encoding
By default, FME Flow tries to detect how your web service handles international character encodings. Beginning with FME Flow 2013, you can manually configure the FME Flow Web Services and Web User Interface for international character encoding. To do this, you must configure each service and web application separately.
To configure international character encoding for a particular FME Flow Web Service or for the Web User Interface:
  1. Open the web application's deployment descriptor web.xml file. This file is installed at <webAppDir>/WEB-INF/web.xml.
  2. Find the <filter> element with <filter-name>i18nFilter and <filter-class>COM.safe.web.servlet.CharsetEncodingFilter.
  3. Add/modify the <init-param> directives to configure international character encodings for this web application according to the table below:
  4. Parameter Name Type Description
    charset string Sets the character set to use. UTF-8 is recommended.
    detect-encodings boolean “true” to automatically detect encodings. “false” to disable.
    auto-encoded list
    A list of comma-separated keywords that specify what should be encoded by the specified character set (see charset). Available keywords:
    • querystring – Encode query strings in the URI.
    • path – Encode the path component of the URI.
    • body – Encode the request body for each request.
For further instructions, see the J2EE Servlet Specification v2.5.
