FME Flow: 2026.3
SASL Authentication Failure 4
Symptom
A Authentication Services connection species SASL as Authentication Methodand GSSAPI as SASL Mechanism, and the following error appears in the log file:
ERROR main 408010 : (Directory Server) Exception: "LDAPException(resultCode=82 (local error), errorMessage='An error occurred while attempting to initialize the JAAS login context for GSSAPI authentication: javax.security.auth.login.LoginException: Message stream modified (41) caused by KrbException: Message stream modified (41)')"
ERROR main 408003 : (Directory Server) Failed to connect to an available server, or no servers were available.
FATAL main 405405 : Security Manager init FAILED
Cause
The Realm setting does not specify the Authentication Realm as a fully-qualified domain name (FQDN).
Resolution
Use the Realm setting on the Edit Server Connection page to specify an FQDN.
