List of Transformers
To filter the list, enter a keyword or category in the search box below.
To download the PDF, click Quick-Reference PDF Guide.
Transformer Categories Transformer Summaries
  2DArcReplacer
Geometries
Replaces or creates feature geometry with a 2D arc as defined in parameters for center point, radii, angles, and rotation.
  2DBoxReplacer
Geometries
Replaces feature geometry with a 2D box defined by specified minimum and maximum x and y values.
  2DEllipseReplacer
Geometries
Replaces or creates feature geometry with a 2D ellipse as defined in parameters for center point, radii, and rotation.
  2DForcer
Coordinates
Geometries
Removes z coordinates from features.
  2DGridAccumulator
Geometries
Creates a regular grid of points or rectangular polygons that span the extents of all input features.
  2DGridCreator
Geometries
Creates a regular grid of points or rectangular polygons of a specified size, position, and coordinate system.
  3DAffiner
3D
Coordinates
Performs a 3D affine transformation (such as offset, rotate, or scale) on the coordinates of the feature.
  3DArcReplacer
3D
Geometries
Replaces the geometry of the feature with a three-dimensional arc whose shape is set by the parameters, which can be either constant floating point values or the values of existing attributes.
  3DForcer
3D
Coordinates
Geometries
Adds z coordinates to features, creating or modifying 3D geometry.
  3DInterpolator
3D
Geometries
Interpolates elevation values along a non-aggregated linear feature from a starting value to an ending value.
  3DRotator
3D
Geometries
Rotates features according to the right hand rule, and in a counter-clockwise direction about the specified axis of rotation.
  3DSlicer
3D
Geometries
Spatial Analysis
Slices geometry along a specified plane.
  Affiner
Coordinates
Performs an affine transformation (such as offset, rotate, or scale) on the coordinates of the feature.
  AffineWarper
Geometries
Spatial Analysis
Performs warping operations on the spatial coordinates of features. It is used to adjust a set of observed input features according to a spatial transform defined by a set of control vectors.
  AggregateFilter
Database
Filters and Joins
Routes features differently depending on if their geometry consists of an aggregate of several geometries, or if it is a simple, single piece geometry.
  Aggregator
Attributes
Calculated Values
Database
Filters and Joins
  AnchoredSnapper
Geometries
Spatial Analysis
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other, where one set of features is non-moving.
  AngleConverter
Calculated Values
Geometries
Strings
Converts angles of a feature's geometry and/or attributes from one representation to another.
  AngularityCalculator
Calculated Values
Data Quality
Calculates the "angularity" of a linear or area feature. Angularity indicates the degree of curvature of a feature. The higher the value, the more curved its geometry.
  AppearanceExtractor
3D
Rasters
Extracts appearance style(s) from the front and/or back side of the geometries.
  AppearanceMerger
3D
Rasters
Sets the front and/or back appearance style(s) of specified geometries to be identical to a specific source geometry.
  AppearanceRemover
3D
Rasters
Removes appearances from the front and/or back side of geometries.
  AppearanceSetter
3D
Rasters
Sets appearance style(s) onto the front and/or back sides of geometries.
  AppearanceStyler
3D
Rasters
Creates an appearance style that can later be applied to a surface.
  ArcEstimator
Geometries
Replaces geometry with an arc described by the first, middle, and last vertices of the input feature.
  ArcGISGridSnapper
Coordinates
Format Specific
Geometries
Spatial Analysis
Simulates the Geodatabase conversion on a feature by snapping its vertices to a grid based on the associated feature class' storage resolution and origin.
  ArcPropertyExtractor
Calculated Values
Extracts the properties of arc geometry, storing the resulting values as attributes.
  ArcPropertySetter
Geometries
Modifies or creates arc geometry according to new coordinates, angles, radii, or rotation values.
  ArcStroker
Geometries
Replaces arc or ellipse geometry with interpolated straight line segments.
  AreaAmalgamator
Cartography and Reports
Geometries
Spatial Analysis
Generalizes area geometry by connecting and combining neighboring features and/or filling in holes and details.
  AreaBuilder
Geometries
Spatial Analysis
  AreaCalculator
Calculated Values
Calculates the planar or sloped area of polygon geometries and adds the results as attributes.
  AreaGapAndOverlapCleaner
Data Quality
Geometries
Repairs area topologies by resolving gaps and overlaps between adjacent areas.
  AreaOnAreaOverlayer
Filters and Joins
Spatial Analysis
  AttributeCompressor
Attributes
Strings
Compresses and (optionally) encrypts the values of the specified attributes. The compressed and encrypted attribute values can be decompressed and decrypted using the AttributeDecompressor.
  AttributeCopier
Attributes
Copies existing attributes to new attributes with user-specified names. The existing attribute remains intact and a new attribute is created that has a different name, but the same values.
  AttributeCreator
Attributes
Adds attributes to features, optionally assigning values. Values may reference adjacent features.
Attributes
Strings
Decompresses and decrypts the values of the specified attributes that were compressed by the AttributeCompressor.
  AttributeDereferencer
Attributes
Sets an attribute value by following a reference from one attribute to another, where the first attribute contains the name of the desired (second) attribute. The referenced value is retrieved and assigned to a new attribute.
  AttributeEncoder
Database
Strings
Web
Encodes the values of the specified attributes to the desired encoding. If the incoming attribute is Null, the type of the attribute will be set to the desired encoding but the output value will be Null.
  AttributeExploder
Attributes
Strings
Creates value pairs (attribute name and attribute value) for every attribute on a feature, and either adds them to a list attribute or creates new features (one for each pair) with new attributes containing both values.
  AttributeExposer
Attributes
Exposes attributes so they can be accessed by downstream transformers and writers.
  AttributeFileReader
Attributes
Format Specific
Workflows
Reads the contents of an external text or binary file and attaches it to a feature as the value of an attribute.
  AttributeFileWriter
Attributes
Format Specific
Workflows
Writes the contents of an attribute to a text or binary file.
  AttributeFilter
Database
Filters and Joins
Routes features to different output ports depending on the value of an attribute. The set of possible attribute values can be entered manually, or extracted from an input source in the properties dialog.
  AttributeKeeper
Attributes
Database
Removes all attributes and list attributes, except the specific ones you specify to be retained.
  AttributeManager
Attributes
Database
Alters one or more attributes by adding, renaming, copying, deleting or re-ordering. Sets values for new, existing, and modified attributes to any combination of constants, attribute values, conditionals, expressions, and parameters. Values can reference adjacent features.
  AttributePivoter
Calculated Values
Filters and Joins
Strings
Restructures and regroups incoming features based on specified Group By attributes and calculates summary statistics to form a Pivot table output.
  AttributeRangeFilter
Database
Filters and Joins
Routes features based on user-defined numeric value ranges.
  AttributeRangeMapper
Database
Strings
Classifies features according to user-defined numeric value ranges, adding a new attribute containing the name of the range it falls within.
  AttributeRemover
Attributes
Removes the selected attributes and list attributes from the feature.
  AttributeRenamer
Attributes
Database
Renames one or more attributes, retaining the attribute’s current values.
  AttributeReprojector
Coordinates
Strings
Reprojects x and y coordinates stored as attributes from one coordinate system to another.
  AttributeRounder
Calculated Values
Database
Strings
Rounds off attributes with numeric values to the specified number of decimal places. Rounding may be nearest, up, or down.
  AttributeSplitter
Attributes
Database
Strings
  AttributeTrimmer
Database
Strings
Removes specified leading and trailing characters from selected attributes.
  AttributeValidator
Data Quality
Database
Strings
Validates any number of attributes against user-defined test conditions, routing the feature according to the outcome of the test(s) and identifying any tests it has failed.
  AttributeValueMapper
Database
Strings
Compares attribute values to a lookup table and assigns new values where matches are found. Mapped values may be stored in a new attribute, or overwrite an existing attribute, including the original source.
  BaseConverter
Calculated Values
Strings
Converts an attribute's value from one numeric system (base) to another, putting the resulting value in a new attribute.
  BinaryDecoder
Database
Strings
Decodes Base64, Base64URL, or HEX text to binary data.
  BinaryEncoder
Database
Strings
Encodes binary data to text using Base64, Base64URL, or HEX encoding methods.
  BoundingBoxAccumulator
Spatial Analysis
  BoundingBoxReplacer
Geometries
  BoundsExtractor
Calculated Values
Extracts a feature’s minimum and maximum coordinate values into attributes.
  BoxConnector
Integrations
Web
Workflows
Connects to the Box file storage service to manage files and folders.
  Bufferer
3D
Spatial Analysis
Creates a buffer zone of specified size around or inside input geometry.
  BulkAttributeRemover
Attributes
Removes all attributes with names that match a given regular expression. This transformer can be used to remove large numbers of attributes that have common naming patterns.
  BulkAttributeRenamer
Attributes
Renames attributes by adding or removing prefixes or suffixes, or replacing text using regular expressions or character strings. This transformer is useful if you need to quickly rename all (or many) of your attributes.
  CenterlineReplacer
Geometries
Spatial Analysis
Replaces area geometry with its centerline or straight skeleton.
  CenterPointExtractor
Calculated Values
Coordinates
Extracts the coordinates of a point located within the feature, its bounding box, or at its center of mass, and stores them as attributes.
  CenterPointReplacer
Geometries
Spatial Analysis
  ChangeDetector
Data Quality
Database
Filters and Joins
Detects changes between two sets of input features.
  CharacterCodeExtractor
Strings
Extracts the character code of the first character in the input string attribute, and adds its integer value in the character set to the feature as another attribute.
  CharacterCodeReplacer
Strings
Sets the result attribute to the character whose numeric code was contained in the source code attribute (or the entered integer).
  ChartGenerator
Rasters
Web
Creates a raster Line, Bar, Scatter, Histogram or Pie chart based on the values of selected attributes, featuring an interactive interface that allows the user to preview selected features with sample data while designing the layout of their chart.
  Chopper
Geometries
  CircularityCalculator
Calculated Values
Data Quality
Calculates the "circularity" of an area feature, which indicates how elongated the feature is.
  Classifier
Calculated Values
Sorts and groups features into a number of classes based on an attribute value, storing their class ID in a specified output attribute.
  Clipper
Spatial Analysis
Divides Candidate features using Clipper features, so that Candidates and parts of Candidates that are inside or outside of the Clipper features are output separately. Attributes may be shared between objects (spatial join).
  Cloner
Workflows
Makes the specified number of copies of the input features and outputs all copies through its single output port.
  ClosedCurveFilter
Data Quality
Filters and Joins
Checks if curves form closed loops.
  CommonLocalReprojector
Coordinates
Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.
  CommonSegmentFinder
Data Quality
Identifies Candidate features with any line segment in common with any Base feature.
  ContourGenerator
Spatial Analysis
Constructs a Delaunay triangulation based on input points and breaklines. Contour lines are then generated from the triangulation.
  ConvexityFilter
Data Quality
Filters and Joins
Determines whether areas, surfaces, and solids are convex or concave.
  CoordinateConcatenator
Calculated Values
Coordinates
Strings
Retrieves the values of all the feature's coordinates into a single string attribute value, separated by delimiters.
  CoordinateExtractor
Calculated Values
Coordinates
Retrieves either specified individual coordinates or all coordinate values from geometry, adding them to the feature as attributes.
  CoordinateRounder
Coordinates
Geometries
Rounds off the coordinates of the feature to the specified number of decimal places.
  CoordinateSwapper
Coordinates
Geometries
Swaps coordinate axes of the input features.
CoordinateSystemDescriptionConverter
Coordinates
Strings
Looks up coordinate system names and definitions between FME’s internal format and common third-party and open source representations, storing the results as an attribute.
  CoordinateSystemExtractor
Coordinates
Retrieves the name of the feature's assigned FME coordinate system into an attribute.
  CoordinateSystemRemover
Coordinates
Removes the assigned coordinate system from features, without modifying geometry or coordinates.
  CoordinateSystemSetter
Coordinates
Assigns a user-specified coordinate system to features, without modifying geometry or coordinates.
  Counter
Calculated Values
Adds a numeric attribute to a feature and assigns a value. Each subsequent feature passing through the transformer receives an incremented value, counting the features.
  CRCCalculator
Calculated Values
Data Quality
Calculates a CRC (Cyclic Redundancy Check) value for a feature and places the calculated CRC value into the attribute specified.
  Creator
3D
Workflows
Creates features using the parameters supplied, and sends them into the workspace for processing.
  CSGBuilder
3D
Geometries
Creates Constructive Solid Geometry (CSG) from pairs of solid geometry features which are input through the A and B ports.
  CSGEvaluator
3D
Recursively replaces the geometry of a feature that has CSG (Constructive Solid Geometry) by evaluating the tree of the CSG solid, effectively removing the constructive aspect of the geometry.
  CsmapAttributeReprojector
Coordinates
Integrations
Reprojects coordinates stored as attributes from one coordinate system to another using the CS-MAP library.
  CsmapReprojector
Coordinates
Integrations
Reprojects feature coordinates from one coordinate system to another using the CS-MAP library.
  Curvefitter
Geometries
Replaces geometry with an optimal path of line segments and arcs, creating smooth, curving lines and areas.
  DatabaseDeleter
Database
Format Specific
Integrations
Workflows
Delete rows in a database table based on the condition specified.
  DatabaseJoiner
Attributes
Database
Filters and Joins
  DatabaseQuerier
Database
Workflows
Executes queries against a database, producing query results and/or schema.
  DatabaseUpdater
Database
Format Specific
Integrations
Workflows
Update fields in a database table based on the condition specified.
  DateTimeCalculator
Calculated Values
Database
Performs arithmetic on date, time, datetime, and interval values.
  DateTimeConverter
Calculated Values
Database
Strings
Converts a set of input date/time attributes from one format to another, in place.
  DateTimeRounder
Calculated Values
Database
Rounds a DateTime value’s day, hour, minute, second, millisecond, microsecond, or nanosecond to a specified interval.
  DateTimeStamper
Calculated Values
Database
Adds the current date, time, or both as an attribute, in either local or UTC time.
  Deaggregator
Attributes
Database
Filters and Joins
  Decelerator
Web
Workflows
Slows down the flow of features through the workspace.
  DecimalDegreesCalculator
Calculated Values
Coordinates
Calculates a decimal degree value from separate degrees, minutes, and seconds (DMS) values, provided as attributes.
  DEMDistanceCalculator
3D
Calculated Values
Rasters
Spatial Analysis
Calculates the distance between a number of input vector lines and the elevation values of a reference DEM raster, and outputs a new DEM raster per input line.
  DEMGenerator
3D
Point Clouds
Constructs a Delaunay triangulation based on input points and breaklines. That triangulation is then uniformly sampled to produce a digital elevation model (DEM points).
  Densifier
Geometries
Adds vertices to linear features at regular intervals.
  DensityCalculator
Calculated Values
Determines the density of a group of Candidate features.
  DGNStyler
Format Specific
Prepares features for output to Bentley Microstation Design V7/V8 by providing a convenient interface to set a variety of Bentley Microstation Design format-specific attributes.
  DimensionExtractor
3D
Calculated Values
Coordinates
Data Quality
Strings
Extracts a feature’s number of dimensions, storing the resulting value of 2 or 3 in an attribute.
  Displacer
Geometries
Spatial Analysis
Solves proximity conflicts between features using a variant of the Nickerson displacement algorithm. This transformer is usually used after generalization.
  Dissolver
Geometries
Spatial Analysis
  DMSCalculator
Calculated Values
Coordinates
Calculates degrees, minutes, and seconds (DMS) from a decimal degrees value provided as an attribute.
  DonutBridgeBuilder
Geometries
Spatial Analysis
Adds internal edges to connect donut holes to the outer shell, producing a non-donut polygon.
  DonutBuilder
Geometries
  DonutHoleExtractor
Geometries
  DuplicateFilter
Data Quality
Database
Filters and Joins
Detects duplicate features based on the value of one or more key attributes.
  DWGStyler
Format Specific
Prepares features for output to AutoCAD DWG/DXF by providing a convenient interface to set a variety of AutoCAD DWG/DXF format-specific attributes.
  ElevationExtractor
3D
Calculated Values
Coordinates
Data Quality
Strings
Extracts a feature’s first z coordinate value, storing it in an attribute.
  EllipsePropertyExtractor
Calculated Values
Extracts the properties of ellipse geometry, storing the resulting values as attributes.
  EllipsePropertySetter
Geometries
Modifies or creates ellipse geometry according to new coordinate, radii, rotation, or orientation values.
  EnvironmentVariableFetcher
Workflows
Fetches a specified environment variable value as an attribute.
  EsriReprojector
Coordinates
Format Specific
Integrations
Reprojects feature coordinates from one coordinate system to another using the Esri reprojection engine.
  ExcelConditionalFormatter
Database
Format Specific
Sets conditional rules and styles on features destined for Excel formats.
  ExcelStyler
Database
Format Specific
Sets row and cell styling on features destined for Excel formats.
  ExpressionEvaluator
Calculated Values
Strings
Performs a mathematical calculation on an expression that consists of FME Feature Functions, String Functions, Math Functions, and Math Operators. The operands and function arguments consist of attributes on the input feature, constant literals, user parameters, as well as functions and operators.
  Extruder
3D
Geometries
Creates line, surface or solid geometries with a fixed cross-sectional profile taken from the original geometry of the feature.
  FaceReplacer
3D
Geometries
  FeatureColorSetter
Assigns colors to incoming features.
  FeatureHolder
Workflows
Stores incoming features until they have all arrived, and then releases them in their original order.
  FeatureJoiner
Database
Filters and Joins
Joins features by combining the attributes and/or geometry of features based on common key attribute values. Performs Left, Inner, and Full joins.
  FeatureMerger
Database
Filters and Joins
Merges the attributes and/or geometries of one set of features onto another set of features, based on matching key attribute values and expressions.
  FeatureReader
Database
Filters and Joins
Format Specific
Spatial Analysis
Workflows
Reads features from any FME-supported format.
  FeatureTypeExtractor
Workflows
Adds an attribute containing the original feature type of a feature.
  FeatureTypeFilter
Data Quality
Database
Filters and Joins
Routes features to different output ports based on their incoming feature type.
  FeatureWriter
Database
Format Specific
Workflows
Writes features to any FME-supported writer.
  FilenamePartExtractor
Strings
Extracts specified parts of a filename path and returns the results as string attributes.
  FMEFlowJobSubmitter
Integrations
Web
Workflows
Submits FME jobs to be run on FME Flow. A job consists of a workspace (housed within a repository on FME Flow) together with values for each of its user parameters.
  FMEFlowNotifier
Integrations
Web
Workflows
Sends a notification to a specified FME Flow instance.
  FMEFunctionCaller
Workflows
Calls a specified FME function, optionally storing the resulting value in an attribute.
  FTPCaller
Integrations
Web
Workflows
Uploads and downloads data from an FTP server.
  Generalizer
Geometries
Web
Simplifies, smoothes, measures, or fits geometry according to a variety of algorithms.
  GeometryCoercer
Geometries
Point Clouds
Resets the geometry type of the feature.
  GeometryColorSetter
Sets colors, via appearances, on geometries (such as surfaces) that support appearances, and match a Geometry XQuery.
  GeometryCopier
Geometries
Copies a feature's geometries onto itself.
  GeometryExposer
Geometries
Exposes geometry names so they can be accessed by downstream transformers and writers.
  GeometryExtractor
Calculated Values
Geometries
Format Specific
Workflows
Extracts geometries of a feature according to the setting of the geometry encoding parameter and the geometry selected.
  GeometryFilter
Data Quality
Database
Filters and Joins
Routes features based on their geometry type.
  GeometryInstantiator
3D
Replaces a geometry definition with independent geometry instances that are copies of the original geometry definition.
  GeometryNameExtractor
Geometries
Extracts geometry names to an attribute.
  GeometryNameSetter
Geometries
Applies names to geometries.
  GeometryPartCounter
Calculated Values
Data Quality
Returns the number of parts in the geometry.
  GeometryPartExtractor
3D
Extracts selected geometry parts based on a Geometry XQuery.
  GeometryPropertyExtractor
3D
Extracts selected geometry labels or traits to feature attributes.
  GeometryPropertyRemover
3D
Removes selected geometry labels or traits.
  GeometryPropertyRenamer
3D
Renames traits and changes the values of geometry labels.
  GeometryPropertySetter
3D
Sets selected geometry labels or traits from feature attributes or constants.
  GeometryRefiner
Geometries
Performs refinements on features geometry.
  GeometryRemover
Geometries
Removes geometries from features.
  GeometryReplacer
Format Specific
Geometries
Workflows
Replaces the geometry of a feature according to the setting of the geometry encoding parameter. This transformer is typically used to restore geometry previously extracted into an attribute by the GeometryExtractor.
  GeometryValidator
Data Quality
Detects selected issues in input features, and optionally repairs detected issues.
  GeoRSSFeatureComposer
Format Specific
Web
Constructs GeoRSS documents from the input features and stores them in the specified attribute for the features that are output by the GeoRSS port.
  GeoRSSFeatureReader
Format Specific
Web
Constructs features out of GeoRSS documents/URLs that are stored in a specified attribute of the input features. The features from the GeoRSS document/URL are output with the attributes from the original feature and are merged, if desired.
  GMLFeatureComposer
Format Specific
Writes out GML features corresponding to feature types from existing GML application schema.
  GOIDGenerator
Calculated Values
Calculates a GOID (Geographic Object IDentifier) for each incoming feature, and adds it as a new attribute.
  GoogleDriveConnector
Integrations
Web
Workflows
Connects to Google Drive to manage files and folders.
  GridInQuestIIReprojector
Coordinates
Integrations
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland.
  GtransAttributeReprojector
Coordinates
Integrations
Reprojects coordinates stored as attributes from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
  GtransReprojector
Coordinates
Integrations
Reprojects feature coordinates from one coordinate system to another using the Gtrans reprojection engine from the National Land Survey of Sweden (Lantmäteriet).
  H3HexagonalIndexer
Calculated Values
Geometries
Computes and manipulates hexagonal hierarchical spatial indexes (Uber H3), and enables spatial data to be grouped into hexagonal grid cells for analysis and visualization.
  HDFSConnector
Integrations
Web
Workflows
Connects to an HDFS (Hadoop Distributed File System) to manage files and folders.
  HoleCounter
Calculated Values
Data Quality
Retrieves the number of holes in donut polygons, storing the result as an attribute.
  HTMLExtractor
Integrations
Strings
Web
Workflows
Extracts structured data from web page or other HTML sources that are formatted for human readability (screen scraping), using CSS selectors to extract portions of HTML content into feature attributes.
  HTMLLayouter
Format Specific
Web
Allows users to combine web reports generated by the HTMLReportGenerator into a bootstrap grid or vertical layout.
  HTMLReportGenerator
Format Specific
Web
Allows users to create a basic web report of vertically-stacked elements using the geometry and selected attributes from features.
  HTMLToXHTMLConverter
Format Specific
Strings
Web
Converts HTML document into valid XHTML document.
  HTTPCaller
Web
Workflows
Accesses a URL via HTTP or HTTPS, using a variety of HTTP methods.
  HullAccumulator
Spatial Analysis
Creates a convex or concave hull based on a group of input features.
  HullReplacer
Geometries
Replaces feature geometry with a convex or concave hull around the feature.
IFCPropertySetDefinitionCreator
3D
Format Specific
Creates a feature whose attributes contain the definition of an IFC property set. The features output from this transformer are similar to the PropertySetDefinition features produced by the IFC reader.
IFCQuantitySetDefinitionCreator
3D
Format Specific
Creates a feature whose attributes contain the definition of an IFC quantity set. The features output from this transformer are similar to the QuantitySetDefinition features produced by the IFC reader.
  ImageFetcher
Rasters
Workflows
Retrieves an image from a URL and outputs a raster feature.
  ImageRasterizer
Rasters
Creates a raster representation of vector or point cloud input features.
  InlineQuerier
Database
Workflows
Creates SQLite database tables from incoming features, executes SQL queries against them, and outputs the results as features.
  Inspector
Data Quality
Workflows
Sends features to the FME Data Inspector for display.
  Intersector
Geometries
Spatial Analysis
  JMSReceiver
Integrations
Web
Using the Java Message System (JMS), receives messages from a message broker.
  JMSSender
Integrations
Web
Using the Java Message System (JMS), sends messages to a message broker.
  JSONAppender
Format Specific
Web
Assembles multiple JSON fragments into a single JSON document.
  JSONExtractor
Format Specific
Web
Extracts portions of JSON (JavaScript Object Notation) formatted text into feature attributes.
  JSONFlattener
Format Specific
Web
Flattens JSON (JavaScript Object Notation) objects, extracting the object keys and values into FME feature attributes.
  JSONFormatter
Format Specific
Web
 Provides options for formatting JSON (JavaScript Object Notation) text.
  JSONFragmenter
Format Specific
Web
Extracts portions of JSON (JavaScript Object Notation) formatted text into new FME features.
  JSONObjectBuilder
Format Specific
Web
Builds a JSON object from feature attributes, or inserts attribute values into an existing JSON object.
  JSONTemplater
Format Specific
Web
Populates a JSON document with FME feature attribute values. The document is provided as a template, and the transformer will use XQuery to insert attribute values and geometry information into the template.
  JSONUpdater
Format Specific
Web
Modifies JSON documents.
  JSONValidator
Data Quality
Format Specific
Web
Validates the syntax of JSON (JavaScript Object Notation) text.
  Junction
Workflows
Brings multiple connections together at a junction point, which outputs a single connection.
  KinesisReceiver
Integrations
Using the Amazon Kinesis service, receives data records from an Amazon Kinesis stream.
  KinesisSender
Integrations
Using the Amazon Kinesis service, sends data records to an Amazon Kinesis stream.
  KMLPropertySetter
Format Specific
Sets common properties for groups of vector and raster features destined for the OGCKML Writer.
  KMLRegionSetter
Format Specific
Sets the region-related KML attributes for a group of features destined for the OGCKML Writer.
  KMLStyler
Format Specific
Creates a common style for a group of features destined for the OGCKML writer.
  KMLTimeSetter
Format Specific
Sets the time-related KML attributes for a group of features destined for the OGCKML Writer.
  KMLTourBuilder
Format Specific
Generates a KML Tour from input features. The tour consists of tour stops that correspond to each input feature.
  KMLViewSetter
Format Specific
Sets the view-related KML attributes for a group of features destined for the OGCKML Writer. Creation of LookAt or Camera views are supported.
  Labeler
  LabelPointReplacer
Geometries
  LatLongToMGRSConverter
Coordinates
Calculates a Military Grid Reference System (MGRS) code based on latitude and longitude values.
  LeftRightSpatialCalculator
Calculated Values
Computes relative position of Candidate input features relative to Base input features.
  LengthCalculator
Calculated Values
Calculates the length of a feature and adds it as a new attribute.
  LengthToPointCalculator
Calculated Values
Calculates the length of a feature from its start until the closest spot to a point, and adds it as a new attribute. The point coordinates are taken from attributes in the original feature.
  LineBuilder
Geometries
Connects sequential point and/or line features to create line or area geometry.
  LineCloser
Geometries
  LineCombiner
Geometries
Connects line features that meet at common start or end points to create longer lines or paths.
  LineExtender
Geometries
Extends line, arc, or path features at both ends by a specified length.
  LineOnAreaOverlayer
Filters and Joins
Spatial Analysis
  LineOnLineOverlayer
Filters and Joins
Spatial Analysis
Overlays lines on lines, intersecting geometry, sharing attributes, and producing intersection points.
  ListBasedFeatureMerger
Filters and Joins
Merges the attributes and/or geometries of one set of features onto another set of features, based on matching list attribute values with key attribute values and expressions.
  ListBuilder
Attributes
Combines attributes of the input features into a single list structure.
  ListConcatenator
Attributes
Concatenates all the values of a list into a single attribute.
  ListCopier
Attributes
Copies a complete attribute list, including all nested attributes, from one list name to another.
  ListDuplicateRemover
Data Quality
Strings
Removes all duplicate values from a list attribute.
  ListElementCounter
Data Quality
Stores the number of member elements found in the specified list into an attribute.
  ListExploder
Attributes
Explodes each list member on each input feature out into its own feature.
  ListExpressionPopulator
Attributes
Populates a new list from a series of attributes. The attributes to be used are specified by the expression parameter. Each attribute's index in the list is specified by the order of the attribute in the sorted result of the regular expression.
  ListHistogrammer
Calculated Values
Data Quality
Computes a histogram of the values found in a list, and returns these in a new list attribute on the feature.
  ListIndexer
Attributes
Copies the attributes of the list element specified by the index to become main attributes of the feature.
  ListPopulator
Attributes
  ListRangeExtractor
Calculated Values
Extracts the minimum and maximum values found in a list.
  ListRenamer
Attributes
Renames or promotes list names or components.
  ListSearcher
Strings
Searches a list to find a value and returns the index of the value in the list.
  ListSorter
Attributes
Sorts the elements of a list.
  ListSummer
Strings
Computes the sum of all the elements of a list.
  LocalCoordinateSystemSetter
Coordinates
Assigns a specified local coordinate system to features, without modifying geometry or coordinates.
  Logger
Workflows
Logs each feature to the translation log at the specified severity. All attributes and geometry of the feature will be output.
  LogMessageStreamer
Workflows
Captures messages from the FME logfile and/or the Logger transformer. The messages are loaded onto features created by the transformer.
  MapboxStyler
Format Specific
Creates a common style for a group of features destined for the GeoJSON writer.
  MapInfoStyler
Format Specific
Prepares features for output to MapInfo MIF/MID or MapInfo TAB by providing a convenient interface to set a variety of MapInfo format-specific attributes.
  MapnikRasterizer
Rasters
Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit.
  Matcher
Database
Data Quality
  MeasureExtractor
Calculated Values
Extracts the measures of geometries that match the given type, and places them in attributes or list attributes.
  MeasureGenerator
Calculated Values
Creates a set of measures attached to the geometry of the feature, where each value is the distance from the start of the line up to that vertex, multiplied by the given Multiplier.
  MeasureRemover
Geometries
Removes measures from a feature's geometry.
  MeasureSetter
Geometries
Sets measure(s) on a point, line, arc, area geometry or a vertex of a linear geometry to attribute value(s) of given attribute(s) or list attribute.
  MeshMerger
3D
Geometries
Merges mesh features (features with IFMEMesh geometries) into a single output mesh.
  MeshSimplifier
3D
Geometries
Reduces the number of triangles in a mesh.
  MGRSToLatLongConverter
Coordinates
Converts Military Grid Reference System (MGRS) code to longitude and latitude coordinate values.
  MinimumAreaForcer
Geometries
Enlarges features smaller than a specified area to that specified minimum size.
MinimumSpanningCircleReplacer
Geometries
Calculates a circle containing all vertices of the input feature, output as either attribute values or geometry.
  ModuloCounter
Calculated Values
Adds an attribute holding the next integer in a sequence, restarting the count at 0 whenever the sequence reaches the specified maximum value.
  MultipleGeometryCoercer
Geometries
Splits an aggregate into multiple geometry columns, with one column for each part of the original aggregate.
  MultipleGeometryFilter
Filters and Joins
Routes features depending on whether or not they have multiple geometries.
  NeighborFinder
Spatial Analysis
Finds the nearest Candidate feature(s) to each Base feature and merges their attributes onto the Base feature. May also be used in Candidates Only mode, where each feature is considered the Base in turn and compared to all other features, but not itself.
  NeighborhoodAggregator
Filters and Joins
Spatial Analysis
Creates aggregates of features based on their proximity to each other. Each aggregate that is created covers approximately the neighborhood width and height (measured in feature ground units).
  NeighborPairFinder
Spatial Analysis
Finds the closest two Candidate features within some maximum distance of each Base feature and some minimum separation in heading between the Candidates and the Base.
  NetworkCostCalculator
Calculated Values
Spatial Analysis
Computes and assigns the cost of the shortest path from a source object to each connected object as the Z-values or measure values of the input features.
  NetworkFlowOrientor
Spatial Analysis
Fixes the flow (direction) of each edge or linear feature in the network to fit the downstream direction to the destination node.
  NetworkTopologyCalculator
Calculated Values
Spatial Analysis
Finds the connected lines that belong to the same network graph.
  NoFeaturesTester
Workflows
Detects whether or not any features have reached a point in a workspace.
  NullAttributeMapper
Attributes
Data Quality
Database
Strings
Maps specified attributes on a feature to specified values. This transformer can map to and from null values, empty strings, and missing attributes.
  NumericRasterizer
Rasters
Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.
  OffsetCurveGenerator
Geometries
Creates offset parallel lines on either side of curve features.
  Offsetter
3D
Spatial Analysis
Adds offsets to the feature's coordinates.
  OneDriveConnector
Integrations
Web
Workflows
Connects to Microsoft OneDrive to manage files and folders.
  OpenAPICaller
Web
Workflows
Accesses an API endpoint defined by an OpenAPI specification via HTTP or HTTPS.
  OrientationExtractor
Calculated Values
Returns a feature's orientation.
  Orientor
Geometries
Adjusts the orientation of a polygonal feature, a surface, or the direction of a linear feature.
  ParameterFetcher
Web
Workflows
Adds an attribute to the feature, supplying it the value of a previously defined parameter.
  PathBuilder
Geometries
Connects sequential line and/or arc features to create path geometry, preserving input segments.
  PathSplitter
Geometries
Splits path geometry into its component line and/or arc segments.
  PDFPageFormatter
Format Specific
Prepares features for output to PDF by providing a convenient interface to set the scale and location of features on a page.
  PDFStyler
Format Specific
Sets the common PDF style attributes for a group of features destined for the GeoSpatial PDF Writer.
  PipeEvaluator
3D
Geometries
Replaces pipe geometries on the feature with an approximated boundary representation solid.
  PipeReplacer
3D
Geometries
Replaces the geometry of the feature with a three-dimensional pipe created by sweeping a stroked disk along the input curve.
  PlanarityFilter
3D
Data Quality
Filters and Joins
Filters features based on their planarity. To be planar, a geometry must have all its points situated in the same plane.
  Player
Workflows
Retrieves features stored in an FME Feature Store (FFS) file and outputs them into the workspace.
  PointCloudCombiner
Point Clouds
Combines features into a single point cloud. Point cloud and non-point cloud geometries are supported.
PointCloudComponentAdder
Point Clouds
Adds new components with constant values to a point cloud.
PointCloudComponentCopier
Point Clouds
Copies selected component values onto either a new or existing component.
PointCloudComponentKeeper
Point Clouds
Keeps only specified point cloud components, discarding all others.
PointCloudComponentRemover
Point Clouds
Removes specified components from a point cloud.
PointCloudComponentRenamer
Point Clouds
Renames an existing component.
PointCloudComponentTypeCoercer
Point Clouds
Alters the data type of point cloud components, and converts component values if required.
  PointCloudConsumer
Point Clouds
Reads point cloud features for testing purposes, including any accumulated point cloud operations. No additional operations are performed, and nothing is done with the features.
  PointCloudCreator
Point Clouds
Creates a point cloud of specified size and density, with default component values.
PointCloudExpressionEvaluator
Calculated Values
Point Clouds
Evaluates expressions on each point in a point cloud feature, including algebraic operations and conditional statements, and sets individual point cloud component values.
  PointCloudExtractor
Point Clouds
Serializes the geometry of a point cloud feature into a Blob attribute, encoding the contents according to a choice of common binary point cloud formats.
  PointCloudFilter
Filters and Joins
Point Clouds
Separates point clouds into multiple features, based on evaluating expressions including component values, and creates a separate output port for each expression defined.
  PointCloudMerger
Filters and Joins
Point Clouds
Merges point clouds by joining points where selected component values match (join key), including x, y, z, and other components. Component values are transferred between point clouds and output is filtered based on matching success and duplication.
PointCloudOnRasterComponentSetter
Point Clouds
Rasters
Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.
  PointCloudPropertyExtractor
Calculated Values
Point Clouds
Extracts the geometry properties of a point cloud feature and exposes them as attributes, optionally checking for their existence, retrieving component properties, and finding minimum and maximum values. Extents may also be recalculated and updated.
  PointCloudReplacer
Point Clouds
Decodes a binary attribute containing encoded point clouds stored as Blobs, replacing the feature’s geometry with the decoded point cloud.
  PointCloudSimplifier
Point Clouds
Reduces the number of points in a point cloud by selectively keeping points based on the shape of the point cloud. The simplified and removed points are output as two discrete point clouds.
  PointCloudSorter
Point Clouds
Sorts the points within a point cloud by one or more component values.
  PointCloudSplitter
Point Clouds
Separates point clouds into multiple features based on component values, color, or first/last return.
  PointCloudStatisticsCalculator
Calculated Values
Point Clouds
Calculates statistics on point cloud components and adds the results as attributes.
  PointCloudSurfaceBuilder
3D
Geometries
Point Clouds
Takes an input point cloud and reconstructs it into an output mesh.
  PointCloudThinner
Point Clouds
Reduces the number of points in (thins) a point cloud by keeping points at a fixed interval, a maximum number of points, or a set quantity of first or last points. Remaining points are discarded.
  PointCloudToPointCoercer
Point Clouds
Converts point clouds to point or multipoint geometries, optionally retaining attribute and component values.
PointCloudTransformationApplier
Point Clouds
Applies a point cloud’s scale, offset, or transformation matrix to it, recalculating component values and removing the transformation values.
  PointOnAreaOverlayer
Filters and Joins
Spatial Analysis
Overlays points and areas, sharing attributes.
  PointOnLineOverlayer
Filters and Joins
Spatial Analysis
Overlays points on lines, splitting lines and sharing attributes.
  PointOnPointOverlayer
Filters and Joins
Spatial Analysis
Overlays points on points, sharing attributes.
  PointOnRasterValueExtractor
Rasters
Spatial Analysis
Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the point feature.
  PointPropertyExtractor
Calculated Values
Extracts point orientation to feature attributes.
  PointPropertySetter
Geometries
Adds or removes point orientation.
  PowerPointStyler
Prepares features for output to the Microsoft PowerPoint Writer by providing a convenient interface to set a variety of Microsoft PowerPoint format-specific attributes.
  PROJAttributeReprojector
Coordinates
Integrations
Reprojects coordinates stored as attributes from one coordinate system to another using the PROJ library.
  ProjectWiseWSGConnector
Integrations
Web
Workflows
Connects to Bentley ProjectWise to manage files and folders.
  PROJReprojector
Coordinates
Integrations
Reprojects feature coordinates from one coordinate system to another using the PROJ library.
  PythonCaller
Workflows
Executes a user-supplied Python script to manipulate features.
  PythonCreator
Workflows
Creates features with a user-supplied Python script.
  RandomNumberGenerator
Calculated Values
Strings
Generates a uniformly distributed random number.
  RasterAspectCalculator
Calculated Values
Rasters
Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, clockwise from north.
  RasterBandAdder
Rasters
Adds a new band to a raster feature.
  RasterBandCombiner
Rasters
Merges coincidental raster features into a single output raster feature, preserving and appending all bands.
RasterBandInterpretationCoercer
Rasters
Alters the interpretation type of individual raster bands, converting cell values if necessary.
  RasterBandKeeper
Rasters
Removes all unselected bands from a raster feature.
  RasterBandMinMaxExtractor
Calculated Values
Rasters
Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute.
  RasterBandNameSetter
Rasters
Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers.
  RasterBandNodataRemover
Rasters
Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data.
  RasterBandNodataSetter
Rasters
Sets a new Nodata value on selected bands of a raster feature.
  RasterBandOrderer
Rasters
Specifies the required order of bands in a raster. Bands are reordered according to the input band indices.
RasterBandPropertyExtractor
Calculated Values
Rasters
Extracts the band and palette properties of a raster feature and adds them to a list attribute.
  RasterBandRemover
Rasters
Removes any selected bands from a raster feature.
  RasterBandSeparator
Rasters
Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations.
  RasterCellCoercer
Rasters
Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes.
  RasterCellOriginSetter
Rasters
Sets the cell origin point within cells in a raster.
  RasterCellValueCalculator
Calculated Values
Rasters
Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters.
  RasterCellValueReplacer
Rasters
Replaces ranges of band values in a raster with single values.
  RasterCellValueRounder
Rasters
Rounds off raster cell values.
  RasterCheckpointer
Rasters
Workflows
Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations.
  RasterConsumer
Rasters
Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features.
  RasterConvolver
Rasters
Applies a convolution filter (sometimes called a kernel or lens) to raster features and outputs the results.
  RasterDEMGenerator
3D
Rasters
Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines.
  RasterDiffuser
Rasters
Enhances the features of a raster image. The RasterDiffuser enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image.
  RasterExpressionEvaluator
Calculated Values
Rasters
Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements.
  RasterExtentsCoercer
Rasters
Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster.
  RasterExtractor
Rasters
Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.
  RasterGCPExtractor
Coordinates
Rasters
Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
  RasterGCPSetter
Coordinates
Rasters
Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.
  RasterGeoreferencer
Coordinates
Rasters
Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.
  RasterHillshader
3D
Rasters
Generates a grayscale shaded relief representation of terrain, based on elevation values.
  RasterInterpretationCoercer
Rasters
Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.
  RasterMosaicker
Filters and Joins
Rasters
Merges multiple raster features into a single raster feature.
  RasterNumericCreator
Rasters
Creates a numeric raster of specified size and resolution, with default cell values.
  RasterPaletteAdder
Rasters
Creates a palette from an attribute, and adds this palette to all selected bands on a raster.
  RasterPaletteExtractor
Rasters
Creates a string representation of an existing palette on a raster and saves it to an attribute.
  RasterPaletteGenerator
Rasters
Generates a palette from the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette.
RasterPaletteInterpretationCoercer
Rasters
Alters the interpretation type of raster palettes.
RasterPaletteNodataSetter
Rasters
Identifies the palette key that matches a raster band’s Nodata value, and sets a value on it.
  RasterPaletteRemover
Rasters
Removes selected palette(s) from raster features.
  RasterPaletteResolver
Rasters
Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands.
  RasterPropertyExtractor
Calculated Values
Rasters
Extracts the geometry properties of a raster feature and exposes them as attributes.
  RasterPyramider
Rasters
Web
Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster.
  RasterRegisterer
Rasters
Transforms an image to minimize its difference with another.
  RasterReplacer
Rasters
Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.
  RasterResampler
Rasters
Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, by interpolating new cell values.
  RasterRGBCreator
Rasters
Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values.
  RasterRotationApplier
Rasters
Rotates a raster feature according to its rotation angle property, interpolating new cell values, updating all other affected raster properties, and producing an output raster feature with a rotation angle of zero.
  RasterSegmenter
Rasters
Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells.
  RasterSelector
Rasters
Selects specific bands and palettes of a raster for subsequent transformer operations.
RasterSingularCellValueCalculator
Calculated Values
Rasters
Performs basic arithmetic operations on the cell values of a raster against a numeric value.
  RasterSlopeCalculator
3D
Rasters
Calculates the slope (maximum rate of change in z) for each cell of a raster.
  RasterStatisticsCalculator
Calculated Values
Rasters
Calculates statistics on raster bands and adds the results as attributes.
  RasterSubsetter
Rasters
Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.
  RasterTiler
Rasters
  RasterToPolygonCoercer
Rasters
Creates polygons from input raster features. One polygon is output for each contiguous area of cells with the same value in all bands.
  RCaller
Format Specific
Integrations
Rasters
Executes an R script that has the ability to access feature data from a temporary R data frame.
  Recorder
Workflows
Saves a copy of all the features that enter to a disk file. This disk file can later be "played back" in the subsequent workspace by using the Player, or viewed using the FME Data Inspector.
  ReframeReprojector
Coordinates
Integrations
Reprojects feature coordinates from one coordinate system to another in Switzerland, using the Reframe library from the Federal Office of Topography (swisstopo).
  ReprojectAngleCalculator
Calculated Values
Coordinates
Converts a given angle from one coordinate system to another.
  ReprojectLengthCalculator
Calculated Values
Coordinates
Converts a given length from one coordinate system to another.
  Reprojector
Coordinates
Reprojects feature x and y coordinates from one coordinate system to another.
  RevitStyler
Format Specific
Prepares features for output to Autodesk Revit by providing a convenient interface to set a variety of Autodesk Revit format-specific attributes.
  Rotator
Geometries
Rotates features in a counterclockwise direction about the specified point by the Rotation Angle parameter (measured in degrees).
  RubberSheeter
Coordinates
Geometries
Variably adjusts vector feature coordinates based on their proximity to control vectors indicating current and desired positions.
  SalesforceConnector
Integrations
Web
Workflows
Connects to Salesforce to read records using Salesforce Object Query Language (SOQL) queries.
  Sampler
Data Quality
Filters and Joins
Workflows
Preserves either a total number of features or a sampling of features, depending on the Sampling Type selection. The remainder of the input features are output through the NotSampled port.
  Scaler
3D
Coordinates
Geometries
Scales x, y, and/or z coordinate values to resize geometry.
  SchemaMapper
Database
Workflows
Converts the existing schema (data model) of features to a new structure, based on mappings defined in an external lookup table.
  SchemaScanner
Database
Workflows
Produces a schema feature representing the feature type definition for each group of input data features.
  SecondOrderConformer
3D
Coordinates
Performs a second-order conformal transformation on the feature's geometry. Depending on the input geometry, a 2D or 3D transformation is performed.
  SectorGenerator
Spatial Analysis
Outputs circular sectors of influence for point features that have directions defined by azimuths (degrees clockwise from North).
  SharedItemAdder
3D
Adds or replaces Appearances, Textures, Rasters, or Geometry Definitions in the internal FMELibrary.
  SharedItemIDExtractor
3D
Extracts Shared Item IDs from the front and/or back side of geometries and adds them as traits or a list attribute.
  SharedItemIDSetter
3D
Sets Shared Object IDs onto the front and/or back sides of geometries.
  SharedItemRetriever
3D
Retrieves Appearances, Textures, Rasters, or Geometry Definitions from the internal FMELibrary.
  SherbendGeneralizer
Geometries
Simplifies geometry while preserving spatial relationships and applying spatial constraints.
  ShortestPathFinder
Spatial Analysis
Computes the shortest path of a line or lines containing a source and destination node in a network based on the length of the input or the cost (specified in an attribute) of each of the edges.
  SlackConnector
Integrations
Web
Workflows
Connects to Slack to post messages and files.
  Snapper
Data Quality
Geometries
Spatial Analysis
Brings lines, segments, end points or vertex points of features together if they are within a certain distance of each other and (optionally) if they have one or more attributes in common.
  Snipper
Data Quality
Geometries
Shortens linear geometry by cutting off the ends.
  SNSSender
Integrations
Web
Using the Amazon Simple Notification Service (SNS), sends messages to an Amazon SNS topic.
  SolidBuilder
3D
Geometries
Constructs solids from surfaces and cuts hollow regions, or voids, in solid features with other solid features. A solid that is cut by another solid must contain that second solid.
  SolidDissolver
3D
Geometries
Spatial Analysis
Dissolves solid features by removing common boundaries to create larger solids. Input attributes may be accumulated.
  Sorter
Database
Workflows
Sorts features according to attribute values.
  SpatialFilter
Data Quality
Database
Filters and Joins
Spatial Analysis
Filters point, line, area, and text features based on spatial relationships.
  SpatialRelator
Data Quality
Filters and Joins
Spatial Analysis
Identifies what types of spatial relationships exist between features.
  SpatialSorter
Spatial Analysis
Workflows
Sorts features geographically (by location).
  SpikeRemover
Data Quality
Geometries
Removes spikes from line, path, and area geometry.
  SQLCreator
Database
Workflows
  SQLExecutor
Database
Workflows
Calculated Values
Calculates statistics based on a designated attribute or set of attributes of the incoming features and adds the results as attributes.
  StreamOrderCalculator
Calculated Values
Computes the Strahler order and/or Horton order of streams in a river network.
  StreamPriorityCalculator
Calculated Values
Calculates the primary and secondary streams of multiple stream networks. The key to determining the priority is the shortest path algorithm using multiple iterations within a network graph.
  StringCaseChanger
Database
Strings
Changes the case of text attributes to UPPERCASE, lowercase, Title case, or Full Title Case.
  StringConcatenator
Database
Strings
  StringFormatter
Database
Strings
Reformats the data held in each specified attribute.
  StringLengthCalculator
Calculated Values
Strings
Calculates the length of strings and the number of bytes in a blob.
  StringPadder
Strings
Pads the selected attributes with a specified character, either on the right or left side.
  StringPairReplacer
Strings
Replaces characters in the value contained in the source attribute based on replacement key-value pairs.
  StringReplacer
Strings
Replaces substrings matching text or patterns described by regular expressions.
  StringSearcher
Strings
Performs a regular expression match on the specified expression.
  SubstringExtractor
Calculated Values
Strings
Extracts a substring from the source attribute. The substring is taken from the range of characters specified.
  SummaryReporter
Data Quality
Workflows
Writes a summary report of features that enter to a disk file.  Features are sorted prior to being summarized.
  SurfaceBuilder
3D
Spatial Analysis
Cuts holes in surface features with other surface features. A surface that is cut by another surface must be co-planar with that second surface, and contain that second surface.
  SurfaceDissolver
3D
Geometries
Spatial Analysis
Detects coplanar regions of input surfaces and dissolves them into single faces. The output faces retain the attributes, traits, and appearances of the input.
  SurfaceDraper
3D
Point Clouds
Spatial Analysis
Constructs a Delaunay triangulation based on input points and breaklines. Input drape features will be overlaid onto the surface model, and output as draped features.
  SurfaceFootprintReplacer
3D
Geometries
Replaces the geometry of a feature with a planar representation of the feature's shadow.
  SurfaceModeller
3D
Point Clouds
  SurfaceOnSurfaceOverlayer
3D
Spatial Analysis
Performs a surface-on-surface overlay so that all input surfaces are intersected against each other and resultant surface features are created and output. The output surfaces can retain all the attributes of the input features in which they are contained.
  SurfaceSplitter
3D
Geometries
Splits a double-sided input surface geometry into two single-sided surfaces – one equal to the front side of the input surface and one equal to the back side of the input surface.
  SystemCaller
Workflows
Runs a program or operating system command, and waits for it to exit before continuing the translation.
  TCPIPReceiver
Integrations
Web
Workflows
Receives raw data over TCP/IP. Produces a feature each time a specified number of bytes is received or a particular sequence is detected.
  TCPIPSender
Integrations
Web
Workflows
Sends raw data to the specified host, which may be another FME workspace running in a different process, (located on the same machine or on a different machine), or any client application that communicates over TCP/IP.
  TempPathnameCreator
Calculated Values
Workflows
Reserves and returns a temporary file or folder path that will be deleted upon translation completion. An optional basename and extension can be supplied to further refine the filename portion of the resulting pathname.
  Terminator
Workflows
Stops a workspace translation when it receives a feature.
  Tester
Data Quality
Database
Filters and Joins
Evaluates one or more tests on a feature, and routes the feature according to the outcome of the test(s).
  TestFilter
Data Quality
Database
Filters and Joins
Filters features by test conditions to one or more output ports.
  TextAdder
Geometries
Replaces any geometry with a single text label at the center of its bounding box.
  TextDecoder
Database
Strings
Decodes a string from a number of different text encodings into plain text.
  TextEncoder
Database
Strings
Encodes a text string using URL, Unicode, XML, HTML, Base64, Base64URL, HEX, or Octal methods.
  TextLocationExtractor
Calculated Values
Replaces text with its location geometry, usually a point.
  TextPropertyExtractor
Calculated Values
Retrieves text property values from text geometry, adding them to the feature as attributes.
  TextPropertySetter
Modifies or creates text geometry according to new coordinates, text string, size, or rotation values.
  TextStroker
Rasters
  TextureCoordinateSetter
Calculated Values
Coordinates
Assigns texture coordinates to surfaces.
  Tiler
Geometries
  TimeWindower
Workflows
Adds a time window attribute to each feature, assigning a Window ID based on either the time the feature arrives at the transformer or a timestamp stored as an attribute.
  TINGenerator
3D
Geometries
Constructs a Delaunay triangulation based on input points and breaklines. The surface model may be output in a number of representations: a triangulated irregular network (TIN), TIN vertices, TIN edges, and triangles.
  TopferIndexCalculator
Spatial Analysis
Takes a set of point, linear, polygonal, and/or aggregate features, and calculates the Topfer Index based on user-provided source and destination scales.
  TopologyBuilder
Spatial Analysis
Computes topology on input point, line, and/or area features, and outputs significant nodes, edges, and faces with attributes describing topological relationships.
  TraitMerger
Filters and Joins
Moves the traits from one geometry onto another geometry. It can also move the attributes from a feature onto a geometry as traits, or the traits from a geometry onto a feature as attributes.
  TransporterReceiver
Integrations
Workflows
Receives features from another FME workspace running in a different process, which may be located on the same or a different machine.
  TransporterSender
Integrations
Workflows
Sends features to another FME workspace running in a different process, which may be located on the same machine or on a different machine.
  Triangulator
Geometries
Breaks an input geometry into triangular units or a mesh.
  UniqueIdentifierGenerator
Calculated Values
Calculates a UUID (Universally Unique IDentifier) or ULID (Universally Unique Lexicographically Sortable Identifier) for each incoming feature, and adds it as an attribute.
  VariableRetriever
Workflows
Retrieves variable values into feature attributes.
  VariableSetter
Workflows
Creates and sets the specified variable to the specified value.
  VectorOnRasterOverlayer
Rasters
Spatial Analysis
Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.
  VertexCounter
Calculated Values
Coordinates
Data Quality
Extracts a feature’s total number of vertices, storing the result in an attribute.
  VertexCreator
Geometries
Creates a single vertex to replace, be appended to, or be inserted into existing geometry.
  VertexNormalGenerator
3D
Coordinates
Geometries
Calculates facet or averaged normals for each vertex of a feature's geometry.
  VertexNormalRemover
3D
Coordinates
Geometries
Removes all vertex normals from a feature’s geometry.
  VertexRemover
Coordinates
Geometries
Removes specific vertices from a feature’s geometry.
  VolumeCalculator
3D
Calculated Values
Calculates the volume of a solid object and stores the value in an attribute. The volume is calculated in cube map units, whatever they are.
  VoronoiCellGenerator
Spatial Analysis
  VoronoiDiagrammer
Spatial Analysis
Generates a Voronoi diagram or Thiessen polygon.
  WebMapTiler
Cartography and Reports
Format Specific
Rasters
Web
Creates series of raster tiles for use in web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. Tiles are produced at varying zoom levels, size, and resolution.
  WorkspaceRunner
Workflows
Runs another FME workspace on the local computer by calling an additional FME process.
  XMLAppender
Format Specific
Web
Assembles several XML documents into one.
  XMLFeatureMapper
Format Specific
Web
Constructs features from XML documents via xfMaps.
  XMLFlattener
Format Specific
Web
Flattens content of XML element(s) into feature attributes.
  XMLFormatter
Format Specific
Web
Provides various options for formatting and cleaning up XML documents.
  XMLFragmenter
Format Specific
Web
Maps elements from an XML document into XML fragments, and optionally flattens the content of the XML elements and the children further as feature attributes.
  XMLNamespaceDeclarer
Format Specific
Web
Declares missing namespaces in XML documents by matching prefixes from another sample XML file whose namespaces are fully declared.
  XMLSampleGenerator
Format Specific
Web
This transformer generates an XML document based on an XML Schema (XSD) file.
  XMLTemplater
Format Specific
Web
Populates an XML document with FME feature attribute values. The document is provided as a template, and the transformer will use XQuery to insert attribute values and geometry information into the template.
  XMLUpdater
Format Specific
Web
Modifies XML documents.
  XMLValidator
Format Specific
Web
Validates the syntax or schema of an XML file or text.
  XMLXQueryExploder
Format Specific
Web
Uses XQuery expression to extract portions of XML text into new FME features.
  XMLXQueryExtractor
Format Specific
Web
Uses XQuery expressions to extract portions of XML text into feature attributes.
  XMLXQueryUpdater
Format Specific
Web
Provides updates to an XML document using XQuery Update expressions.
  XSLTProcessor
Format Specific
Web
Workflows
The XSLTProcessor uses an XSL (eXtensible Stylesheet Language) stylesheet to convert an XML document.
Package Transformer Categories Summary
  AmazonAthenaConnector
Web
Connects to Amazon Athena to query Amazon S3 datasets.
  ArcGISAttachmentConnector
Integrations
Web
Workflows
Connects to an ArcGIS Feature Service to manage attachments.
  ArcGISBranchVersionManager
Integrations
Web
Workflows
Connects to an ArcGIS Enterprise Version Management Server to manage a feature service's branch versions.
  ArcGISOnlineConnector
Integrations
Web
Workflows
Connects to Esri ArcGIS Online or Portal for ArcGIS to manage ArcGIS items.
  AutodeskBIM360DocsConnector
Integrations
Web
Workflows
(Deprecated) Accesses BIM 360 Docs and Autodesk Construction Cloud to upload, download, or delete files and folders or list file/folder information.
  AutodeskDocsConnector
Integrations
Web
Workflows
Connects to Autodesk Docs, Autodesk Construction Cloud or Autodesk Build to manage files and folders.
  AWSIoTConnector
Web
Connects to the AWS IoT Core messaging broker to send and receive messages.
  AzureAIVisionConnector
Web
Connects to the Azure AI Vision service to detect objects in images.
  AzureBlobStorageConnector
Integrations
Web
Workflows
Connects to Azure Blob Storage to manage files and folders.
  AzureEventHubsConnector
Web
Connects to Azure Event Hubs to send, receive, and checkpoint messages.
  AzureFileStorageConnector
Integrations
Web
Workflows
Connects to Azure Files to manage files and folders.
  AzureIoTConnector
Web
Connects to the Azure IoT Hub to publish and receive messages.
  AzureQueueStorageConnector
Integrations
Web
Workflows
Connects to Azure Queue Storage to send and receive messages.
  AzureServiceBusConnector
Integrations
Web
Workflows
Connects to Azure Service Bus to send and receive messages.
  AzureTextAnalyticsConnector
Web
Connects to Azure Text Analytics Service for natural language processing on text.
  CesiumIonConnector
Web
Connects to Cesium ion to manage assets.
  CityEngineModelGenerator
3D
Geometries
Integrations
Generates 3D models from input geometries and ArcGIS CityEngine rule packages (*.rpk).
  CKANConnector
Integrations
Web
Workflows
Connects to a CKAN open data portal to manage datasets and resources.
  ComprehendConnector
Web
Connects to Amazon AI Comprehend for natural language processing on text.
  DocumentPDFStyler
Prepares features for output to the DocumentPDF Writer by applying styling with PDF format-specific attributes.
  DocumentStyler
Prepares features for output to the OpenDocument Text Writer by applying styling with format-specific attributes.
  DropboxConnector
Integrations
Web
Workflows
Connects to Dropbox to manage files and folders.
  Emailer
Integrations
Web
Sends email via Simple Mail Transfer Protocol (SMTP), Gmail, or Microsoft Mail.
  EthereumConnector
Web
Connects to the Ethereum blockchain network to manage transactions, contracts, and more.
  Geocoder
Integrations
Web
Uses various external web services to convert addresses to coordinates or to find the closest addresses to coordinates (reverse geocode).
  GoogleBigQueryConnector
Database
Web
Connects to Google BigQuery to load and query tables .
  GoogleCloudPubSubConnector
Web
Connects to Google Cloud Pub/Sub to create topics and subscriptions or send and receive messages.
  GoogleCloudStorageConnector
Integrations
Web
Workflows
Connects to Google Cloud Storage to manage files and folders.
  GoogleGeminiConnector
Integrations
Connects to Google Gemini models for content generation, image creation, image editing, speech, and embeddings.
  GoogleIoTConnector
Web
(Deprecated) Connects to the Google IoT Core to send and receive messages.
  GoogleLanguageConnector
Web
Connects to Google Cloud AI for natural language processing on text.
  GoogleVisionConnector
Rasters
Web
Connects to the Google Vision AI API for object detection in images.
  IBMIoTConnector
Web
(Deprecated) Connects to IBM’s Watson IoT Platform through the MQTT protocol to send and receive messages.
  IBMMQConnector
Integrations
Web
Workflows
Connects to an IBM MQ 9.x Queue Manager to send or receive messages and publish or subscribe to topics.
  KafkaConnector
Web
Connects to Apache Kafka, Confluent, RedPanda or other Kafka-compatible data stream services to send and receive messages.
  MCPCaller
Integrations
Connects to an MCP (Model Context Protocol) server to work with tools, resources, and prompts.
  MicrosoftCopilotConnector
Web
Connects to Microsoft 365 Copilot to chat with the Copilot agent and retrieve text content.
  MQTTConnector
Web
Connects to an MQTT broker to send and receive messages.
MSWordStyler
Prepares features for output to the Microsoft Word Writer by providing a convenient interface to set a variety of Microsoft Word format-specific attributes.
  NLPClassifier
Filters and Joins
Strings
Using a trained model, this transformer classifies natural language text into different categories. It can be used for filtering, sentiment analysis, and other tasks.
  NLPTrainer
Filters and Joins
Strings
Trains a natural language processing (NLP) classification model based on the user’s specifications and the provided data.
  OpenAIConnector
Web
Connects to OpenAI or OpenAI-compatible services to access OpenAI or provider-specific models.
  RabbitMQConnector
Integrations
Web
Workflows
Connects to a RabbitMQ AMQP 0-9-1 broker to send and receive messages.
  RekognitionConnector
Web
Connects to Amazon Rekognition for object detection in images.
  S3Connector
Integrations
Web
Workflows
Connects to Amazon S3 to manage files and folders.
  SharePointListAttachmentConnector
Integrations
Web
Workflows
Connects to a SharePoint list item to manage attachments.
  SharePointOnlineConnector
Integrations
Web
Workflows
Connects to Microsoft SharePoint to manage files and folders.
  SQSConnector
Web
Connects to the Amazon Simple Queue Service to send and receive messages.
  TrelloConnector
Integrations
Web
Workflows
Connects to Trello to manage boards, lists, and cards.
  TrimbleConnectConnector
Integrations
Web
Workflows
Connects to Trimble Connect to manage files and folders.
  TrimbleUnityConnector
Integrations
Web
Workflows
Connects to Trimble Unity or Cityworks to manage cases, inspections, service requests, and work orders.
  WebODMConnector
3D
Integrations
Point Clouds
Rasters
Web
Connects to a WebODM web application or NodeODX processing node to run photogrammetry jobs on drone imagery.
  WebSocketConnector
Web
Workflows
Connects to a WebSocket server to send and receive messages.
  WordToDocumentPDFStyler
Prepares Microsoft Word format for use in the Document PDF Writer.
  YAMLtoJSONConverter
Format Specific
 Converts YAML to JSON.
