Microsoft SharePoint Online List Writer Parameters
Connection
This reader uses an FME web connection for authentication. The web connection can be of two supported web service types:
Microsoft SharePoint Online (safe.microsoft-sharepoint): This is used for connections to Azure Apps that require Delegated permissions to access Microsoft Graph. It is recommended to create a new web service from the shipped webservice which replaces the Client ID with the Client ID of your own Azure App.
Microsoft Graph (App Only): This is used for connections to Azure Apps that require Application permissions to access Microsoft Graph. See more details at https://support.safe.com/hc/en-us/articles/30678084674189-How-to-Create-a-SharePointOnlineConnector-Web-Connection-with-Application-Permissions
SharePoint supports only work or school Microsoft accounts.
Specify (or browse for) a SharePoint site that contains Lists.
Advanced
This setting enables the creation of tables without data features.
- No – Tables are only created when receiving data features.
- Yes – Tables are created without data features if possible.
