Creating and Modifying User Parameters
To create user parameters and manage existing ones, open the User Parameters dialog. From the Navigator, right-click on the User Parameters icon, and select Manage User Parameters. Alternatively, from the menu, select Build > Manage User Parameters.
In the User Parameters dialog, the left pane lists all the existing user parameters for the workspace. (They are also listed in the User Parameters section of the Navigator.) You can click and drag on the parameters or use the toolbar icons to perform the following:
- Change the order of the parameters at runtime. (You can also reorder the parameters in the Navigator by dragging them up or down.) Order is important because it affects when parameters are evaluated in the workspace. In particular, the value of one parameter may depend on another parameter that is evaluated earlier.
- Remove a parameter.
- Edit a parameter: Click on one to select it. The parameter's properties display on the right pane.
- Add a parameter: Click the Insert icon (+) and select the type of user parameter you want to add (see Parameter Types, below). The parameter is added below the currently-selected parameter. In the right pane, configure the properties of the parameter according to its type (see Parameter Properties (Right Pane), below).
- Arrange parameters in group boxes: Click the Insert icon and select Group Box. In the left pane, a group box is added below the currently-selected parameter. Click and drag other parameters into the group box as desired. In the right pane, configure the properties of the group box (you may need to re-select the group box to show its properties). See Parameter Properties (Right Pane), below.
When finished, click OK.
To view how the parameters display at runtime, click Preview.
Parameter Types
| Parameter Type | Creates a Parameter to... |
| Attributes > Select Attributes | Choose feature type attributes, or items from a comma-delimited or space-delimited attribute list. Choices only populate in the context of a reference to the user parameter in the workspace, such as when the Attributes parameter of a StringReplacer transformer references a Select Attributes user parameter. |
| Attributes > Expose Attributes | Choose feature attributes to expose for use in downstream components of the workspace. |
| Choice | Choose one or more values, or select/deselect a checkbox. |
| Color | Select a color value. |
| Connection > Database Connection | Choose a database connection. |
| Connection > Web Connection | Choose a web connection. |
| Datetime | Enter a date and time. For information about output formats, see Standard FME Date and Time Format. |
| Encoding | Choose from a list of character encoding conventions supported by FME. |
| File/Folder/URL | Choose the names and paths of existing files or folders, an output file or folder, or a URL. |
| Message | Display a message at runtime. |
| Number | Enter an integer or floating-point number. The number can be bounded or unbounded based on the specified Configuration. |
| Password | Enter a password. |
| Spatial > Coordinate System | Choose a coordinate system. |
| Spatial > Define Geometry | Enter a geometry as a set of spatial coordinates in GeoJSON. When a workspace containing a visible geometry parameter is run from FME Flow, an interface is available for displaying the specified coordinates on a map and specifying the desired geometry. For more information, see Using the Geometry Parameter. Tip To handle the JSON data returned by this parameter: Use a GeometryReplacer transformer to turn the parameter value into a real geometry. Specify GeoJSON as the GeometryEncoding. Use a JSONExtractor transformer to extract the coordinate values. For example, to extract X/Y coordinate values to a point feature, specify json["coordinates"][0] and json["coordinates"][1]. |
| Spatial > Select Geometry | Select an available geometry from the FME Geometry Model. |
| Spatial > Reprojection File | Choose a grid shift file for reprojecting data. |
| Table |
Enter data in a table. |
| Text | Enter a text string in a variety of supported syntaxes. You can also enter a SQL Query on a specified database connection. |
| Advanced > Scripted Selection | Access a callback method in a Python module that returns values available for selection and which may be obtained remotely, such as from a web service. Scripted selection parameters are useful in configuring *Connector transformers to access resources (for example, the Folder parameter of the GoogleDriveConnector transformer). For more information about using Python with scripted selection parameters, see the FME Packages SDK Guide. |
| Advanced > Scripted Value | Access a Python script that assigns the value of a parameter to the workspace at runtime. |
A short, unique name for the parameter (or group box). This name is used to reference the parameter in values (for example, $(myIdentifier)) and menus.
A label for the parameter or group box.
If checked, the specified Label appears when you run the workspace.
If checked, the workspace does not run unless the user inputs a value. If unchecked, an input value is not required for this parameter.
The parameters required in this field depend on the parameter type you choose.
- Select Single: Allows selecting a single attribute name from a drop-down.
- Select Multiple: Allows selecting multiple attribute names from a list box.
- List Support:
- None: Allows selecting names of both regular attributes and list attributes. However, if a list attribute name is selected, the user is prompted further to select a list element name. Specify this option if the place where the list attribute is used in the workspace does not support list attributes. For example, if the list attribute is used in a Logger transformer, you must specify a list element for the Logger to recognize it as an attribute.
- Full: Allows selecting names of both regular attributes and list attributes. Specify this option if the place where the list attribute is used in the workspace supports list attributes.
- Exclusive: Allows selecting only list attribute names. Specify this option to restrict selection only to list attributes, and the place where the list attribute is used in the workspace supports list attributes.
- Allow New Attributes: If Select Single is specified, this option allows the user to specify a new attribute name instead of selecting an existing attribute.
- Exclude Incoming: If checked, the user is prevented from selecting names of format and user attributes that originate from any reader feature types.
- Format Attributes:
- None: The user is prevented from selecting any format attribute names.
- Upstream Reader: The user can select format attribute names defined only on reader feature types in the workspace.
- Downstream Writer: The user can select format attribute names defined only on writer feature types in the workspace.
- Both: The user can select format attribute names defined on both reader and writer feature types in the workspace.
- User Attributes:
- None: The user is prevented from selecting names of any user attributes.
- Upstream Reader: The user can select names of user attributes defined only on reader feature types in the workspace.
- Downstream Writer: The user can select names of user attributes defined only on writer feature types in the workspace.
- Both: The user can select names of user attributes defined on both reader and writer feature types in the workspace.
- Filter Attributes By Port: Restricts the selection of attributes to those that enter the specified port.
You can populate the choices to display in a Dropdown, List, Tree, or as a Standalone checkbox.
If Tree is selected, specify a Tree Node Delimiter (under Advanced) for the nodes of the tree. Then specify the choices, using the delimiter to indicate under which node to place the value.
For example, this configuration uses a comma to delimit building choices by building site:
Mouse-over to view:
When the parameter is visible, the choices appear like this:
Mouse-over to view:
If List or Tree is specified, Choice List Delimiter (under Advanced) specifies the delimiter that separates multiple values as they are selected for display in the parameter values prompt at runtime. The default delimiter is a space. Values that contain spaces are wrapped in double quotes.
- Path Selection:
- Multiple Paths: Allows for selecting multiple items.
- Single Path: Allows for selecting a single item.
- Existing Path: Allows for selecting a single item that must already exist on the system at runtime.
- Specify Extension Filters: If checked, allows you to apply filters on the filenames that can be selected. Specify the filters in the Filter field, and an optional description in the Description field. Wildcard characters and logical operators are supported in the Filter field. For example, to allow any file with a .shp extension, specify *.shp. To add or remove filters, or move filters higher or lower in the list, click the add (+), remove (-), or directional arrow symbols. To specify more than one condition in the same filter, use the OR operator; for example, *.shp OR *.dbf. To allow any file to be selected, leave this field blank.
- Restrict URL Schemes: If Items to Select is URL, check this box to specify the URL protocols that are allowed. http and https are listed by default. To specify other protocols, double-click inside an empty row, type the protocol, and press enter. To add or remove protocols, select and click + or -, respectively.
You can configure the following parameters if Geometry Encoding is GeoJSON:
- Geometry Types: The geometries that may be specified. If the coordinates that are entered do not validate to any of the specified geometries, an error is returned.
- Specify initial bounds for map display: If checked, the interface for entering coordinates is limited to the specified Top, Left, Bottom, and Right coordinates.
- Number of Columns: Specify the number of columns for the table
- Bottom Toolbar:
- Move Up and Down: If checked, enables the toolbar widgets that allow the user to move table rows.
- Import: If checked, enables the Import widget on the toolbar that allows the user to import data into the table.
- Delimiter:
- Column: Specify how columns are delimited in the table's metadata.
- Row: Specify how rows are delimited in the table's metadata.
Configuring Table Columns
For each column, click on a column name to show Column Configuration settings. To return to table settings, click on the table name.
- Column Header: If checked, allows you to update the column name.
- Type: Specify the type of data the column accepts. These types correspond to the Parameter Types that are available for other user parameters. For information about the settings for each type, see <Parameter type> Configuration, above.
- Editor Syntax: Specifies the type of editor for entering text.
- Layout:
- Single-Row Input: Creates a field to enter a single line of text.
- Single-Row Input with Popup Editor: Allows the option of using a Text Editor to enter a single line of text.
- Embedded Editor: Allows entering a multi-line text string with an editor embedded in the parameter dialog.
- Trim Whitespace: If checked, any leading or trailing white space, commas, or other common delimiters are trimmed.
- Allow Arithmetic Expression: Allows use of an Arithmetic Editor to form all or part of the entry.
- Select Parameter to Save the Text String: Allows you to assign the value of another text parameter to populate the Test String field.
- Editor Functionality: If Editor Syntax is Sql or XQuery, specify the editor functionality:
- Database Format: If Editor Syntax is Sql, specify the database Format of the SQL query, and the database Connection for access to the database schema.
- SQL Statement Type: If Editor Syntax is Sql, specify if the editor validates a Full SQL Statement or only a WHERE Clause.
- Functions to Show: If Editor Syntax is XQuery, specify the functions to include in the editor.
- Add Sample Generation Button: If Editor Syntax is XQuery, the editor includes a Generate button that opens a dialog to assist in generating a sample query with prompts for the required XQuery schema and elements.
- Convert All XQuery Functions into JSON Equivalents: If Editor Syntax is XQuery, Xquery functions output in JSON format.
Tip For information about working with database connections, see Using Database Connections.
If Editor Syntax is Plain Text:
If Editor Syntax is Regex:
- Python Entry Point: The name of the Python module that accesses resources. The Python package containing the module must be built and installed to FME. For more information, see the FME Packages SDK.
- Input Parameters: Parameter values required for the Python module to run; for example, the value from a user parameter of type Web Connection that was created to access a web service.
- Selection Type: Specifies the type of values available for selection:
- Items: Only files are available for selection.
- Containers: Only folders are available for selection.
- Items and Containers: Files and folders are available for selection.
- Allow Multiple Selection: If checked, more than one value can be selected.
- Items Have Hierarchy: If checked, the hierarchical path structure is preserved in the presentation of values that are selected.
- Allow Root Selection: If checked, the root folder of the resource being accessed is available for selection.
- Container Icon: In the selection dialog, the icon to display with containers.
- Item Icon: In the selection dialog, the icon to display with files.
- Supports Search: If checked, a Search field is added to the selection dialog.
- Name Matches Identifier: If checked, any names of resource values that match their identifiers are not editable in the Advanced Selection Editor. If unchecked, any names of resource values that match their identifiers are editable, while the names of resource values that do not match their identifiers are not editable.
- Input Constants: Any additional Key-Value data that may be required for the Python module.
If the selected item on the left pane is a group box, and not an individual parameter, you can configure the following:
- Fixed: The group box is neither Collapsible nor Checkable.
- Collapsible: The group box can be manually expanded and collapsed.
- Checkable: The group box can be manually expanded and collapsed, and the ability to edit its contents can be toggled with a checkbox.
- State: If Collapsible or Checkable is selected:
- Automatic: The default state of the group box is either expanded or collapsed, depending on default factors of the operating system.
- Open: The default state of the group box is expanded.
- Closed: The default state of the group box is collapsed.
- Conditional : If Collapsible is selected, check this setting to control the state of the group box based on the value of another parameter that is provided above the group box. The state of the group box depends on whether the value of the previous parameter specified in the If clause Is or Is Not the specified value. Depending on the results of the If clause, the state of the group box is controlled in the Then and Else clauses as either expanded (Open) or collapsed (Closed).
- Grid Layout: Select this parameter to arrange the group box items in 2 or 3 columns.
- Default Checkbox State: If Checkable is selected, and this setting is unchecked, the default state of the group box is unchecked. If this setting is checked, the default state of the group box is checked.
The parameter specified in the If clause must be a type that allows specifying a single value, such as a Yes/No parameter, a specified Text string, or a Choice parameter that does not Allow Multiple Selection.
- Always Show: The parameter or group box is presented to the user when the workspace runs.
- Always Hide: The parameter or group box is not presented to the user when the workspace runs.
- Conditional: The visibility of the parameter (or group box) is based on the value of one or more parameters that are provided at runtime prior to this parameter. The visibility of the parameter depends on whether the value of the previous parameter specified in an If or Else If clause meets the condition relative to a specified value.
- Single Condition: Allows you to specify a single If-Then-Else clause, based on the value of one other parameter provided at runtime prior to this parameter. Depending on the results of the If clause, the visibility of the parameter is controlled in the Then and Else clauses as enabled (Show as Enabled), disabled (Show as Disabled), hidden (Hide), or hidden and disabled (Hide and Disable). If the parameter type is Message, the visibility of the parameter is controlled in the Then and Else clauses as visible (Show) or hidden (Hide).
- Compound Condition: Allows you to specify multiple Else If clauses. To construct each If and Else If condition, double-click inside its respective Test Condition field to open the Conditional Value Definition dialog. In this dialog, each condition is constructed with an optional Logic operator, a Left Value that resolves to one other parameter provided at runtime prior to this parameter, a conditional Operator, and a Right Value against which to test the condition, where applicable. Within this dialog, you can link multiple test clauses with the Logic operator. For each If or Else If clause, specify Visibility as enabled (Show as Enabled), disabled (Show as Disabled), hidden (Hide), or hidden and disabled (Hide and Disable). If the parameter type is Message, specify Visibility as visible (Show) or hidden (Hide). Use the buttons underneath the clauses pane to add, remove, or move clauses.
Operator |
Description |
| Is | Equals |
Is Not |
Does not equal |
Is Empty |
Left Value is null, missing, or empty. |
Is Not Empty |
Left Value is not null, missing, or empty. |
Contains |
Tests that Right Value occurs somewhere in Left Value. |
Does Not Contain |
Tests that Right Value does not occur anywhere in Left Value. |
Matches RegEx |
Tests that Left Value matches a string pattern described by a regular expression in Right Value. |
Is Enabled |
The state of Left Value is enabled. |
Is Not Enabled |
The state of Left Value is disabled. |
Less than |
Less than or equal to |
Greater than |
Greater than or equal to |
The parameter specified in the If (or each Else If) clause must be a type that allows specifying a single value, such as a Yes/No parameter, a specified Text string, or a Choice parameter that does not Allow Multiple Selection.
For more information, see Controlling Parameter Visibility.
- Enable Contextual Options Based on Where the Parameter is Used: If selected, Transformer Parameter Menu Options are available for the parameter.
- Hide Parameter Menu Button: If selected, Transformer Parameter Menu Options are not available for the parameter.
Choose the default value that will be used.
Modifying User Parameters in the Navigator
To edit the default value of a user parameter
Select the parameter, right-click, and select Edit Value. Alternatively, double-click on the parameter.
To edit the default value of multiple user parameters
Right-click on User Parameters, or any single user parameter, and select Edit User Parameter Default Values.
To remove a user parameter
Select a parameter, right-click, and select Delete.
To apply the value of a user parameter to one or more other parameters
Select the parameter, right-click, and select Apply to.
