FME Form: 2026.2 BETA
Using Web Connections
Many processes in FME Form require you to connect and authenticate to a web service in order to use them. For example, when you use an HTTPCaller transformer, you may need to authenticate to a web service, such as Google BigQuery. Similarly, if you want to connect to an FME Flow, you must specify a set of connection parameters. Web connections provide a convenient and secure way to store and reuse these connection parameters. Each time you need to specify the same connection parameters, you can use the connection, rather than re-entering the parameters. If the connection parameters change, you can edit them in one place, rather than in each workspace that uses the connection.
Managing Web Services
FME Form must be registered to use the web services to which you want to connect. Although many of the most common web services are already registered in FME for testing purposes, we recommend defining your own for production purposes. Use Utilities > FME Options > Web Connections to manage web services. For more information, see Managing Web Services.
In other cases, FME provides only a reference template to the web service. To use the service, you must likewise provide your credentials in order to use it. If the service adheres to the OAuth 2.0 standard, you can provide these credentials dynamically when adding a connection (see Working with Web Connections in a Workspace, below).
Tip  To create a connection to an FME Flow that authorizes as a user imported from Microsoft Azure Active Directory, you must define a Microsoft Azure Active Directory web service. For more information, see Managing Web Services.
Adding Web Connections
It is usually more convenient to add a web connection at the time you are using one in a workspace or connecting to FME Flow (see below). However, you can also add a web connection in Utilities > FME Options > Web Connections, and use it later in a workspace.
Adding Web Connections from FME Flow
If your Connection Storage setting, under Utilities > FME Options > Default Paths, is set to FME Flow, you can access the same web connections as those on the specified FME Flow. For more information, see Default Paths.
Using Web Connections to Connect to FME Flow
Reusing a Web Connection
Note  If you did not create a connection, it may not be available for you to use unless its visibility is updated. For more information, see FME Options: Web Connections.
  • Change the connection parameters.
  • Change a web connection to one that exposes the connection parameters in the workspace.
  • Change a connection whose parameters are exposed in the workspace to a web connection.
See Also
