FME Flow: 2026.2
Topic Monitoring
Select System Configuration > Network & Email tab.
These settings are typically configured only when Installing a Scalable, Fault-Tolerant FME Flow or when using a load balancer. For more information, see Set Up the Load Balancer and Configure with FME Flow
