FME Flow: 2026.2
Restoring an FME Flow Configuration
When restoring an FME Flow configuration, keep in mind the following:
- If you are restoring from a backed-up configuration that was using custom System Encryption, you must restore to a system that is using the same custom encryption key as the backup.
- If Version Control was enabled on the backed-up configuration, and configured with a remote Git repository, the restored FME Flow does not automatically synchronize with the repository. That is, the restored FME Flow does not automatically perform a Fetch From Remote operation. To avoid errors, be sure to fetch updates from the repository before pushing updates to the repository.
- Any messaging to or from Automations triggers or external actions, or Notification Service topics, is disabled during the restore operation. This prevents the restore operation from triggering unintended notifications from any actively-configured triggers or publications.
- You must reconfigure the URL of any Remote Engines Services connections.
- For general information, see Backup & Restore.
To Restore an FME Flow Configuration
- Click Restore Backup. The Restore FME Flow page opens.
- File Location: Select a location from which to restore, depending on where the backup (.fsconfig) file was saved (see Backing Up an FME Flow Configuration):
- Upload: Restores from a backup file saved to location outside of Resources.
- Choose a .fsconfig file: Click inside the upload box to select the .fsconfig file to restore. Or, drag and drop the file onto the box.
- Resources: Restores from a backup file saved to a location on the Resources page.
- Resources Location: Click the ellipsis (...) to select the Resources folder that contains the backup file. To select a lower-level folder, click the top folder to open it.
- Post to Topic on Success/Failure: (Optional) FME Flow is pre-configured to publish content about the success or failure of a backup or restore operation. By default, this content is delivered to the MIGRATION_ASYNC_JOB_SUCCESS notification service topic. You can configure an Automations external action to notify you over a supported protocol when a backup or restore succeeds or fails. For more information, see Monitoring FME Flow Events from Topics.
Overwrite Items: In general, when Allow items to be overwritten if they already exist is checked, items on the current instance are overwritten by items in the backed up configuration of the same name. If not checked, only items from the backed up configuration that do not exist on the current instance are imported; nothing is overwritten.
When using Overwrite Items, keep in mind the following, depending on the component that is being restored:
- Services: The restore operation is the same, whether checked or unchecked: Services missing on the target FME Flow are added; existing services are not updated. This is to prevent breaking service definitions on the target FME Flow.
- Notifications: If checked, topics, subscribers, and publishers missing on the target FME Flow are added; existing ones are updated. A union is performed between topic registrations already present on the target server and topic registrations received from the source.
- Security: If unchecked, users, roles and tokens missing on the target FME Flow are added; existing ones are not updated. A union is performed between the permissions already present on the target server and the permissions received from the source. If checked, users, roles and tokens missing on the target server are added; existing ones are not updated. Permissions for roles that are present on both the source and target servers are overwritten, and permissions for roles present only on the target server are left unchanged.
- Resources: If unchecked, files or folders that are missing are added; existing ones are not updated. If checked, files or folders that are missing are added; existing ones are updated. In either case, if a root resource of the same name is not defined on the target server, the resource package is not imported.
- System Events: If unchecked, the configurations of all system events return to their default states. That is, all system events are enabled, and email notifications are not configured.
- Favorites: Any designations by users of a repository item as a 'favorite' are migrated if the repository item and user exist, and if the repository item is not already a favorite of the user, regardless of this setting.
- Performance metrics for workspaces and schedules: If checked, performance metrics are overwritten. If a metric does not exist on the source FME Flow, then the corresponding value on the target FME Flow is cleared.
- Error Handling:
- Stop restore on first error: If selected, the restore stops after encountering the first non-fatal error.
- Skip non-fatal errors: If selected, FME Flow continues restoring after encountering a non-fatal error.
Note A restore operation always stops after encountering a fatal error, regardless of this setting.
If an error is encountered and Skip non-fatal errors is specified, some items in the import may be missing or may not behave as expected. Following the restore operation, you can review any errors or warning that were encountered (see below). - Click Import File. The restore proceeds, accompanied by a message.
- Allow items to be overwritten if they already exist is checked.
- The backup file contains the same user who is performing the restore, but the user session tokens are different. This is likely the case, unless the backup file was created in the current login session.
Depending on the complexity of the restore operation, one or more log files is created. To view the most recent log entries directly in the latest log file, click View Details. If errors or warnings were encountered during the restore operation, they are listed under Status Summary. To view an entry in more detail, click its corresponding VIEW IN LOG icon. If you are viewing an entry in the most recent log file, it displays directly in the Status Summary. If you are viewing an entry in a log file created earlier in the restore operation, it opens in the log file saved to Resources.
