FME Flow: 2026.2
Dropbox Directory
The Dropbox Directory trigger monitors activity on a Dropbox folder, and sends JSON messages about that activity, which can include adding, changing, and deleting files.
The Dropbox Directory trigger has two output ports. The success port (✔) can send a message if the trigger polls successfully. The failure port (x) can send a message if the trigger fails to poll.
Configuring Your Dropbox Account App
Before creating a Dropbox Directory trigger on a Dropbox account, you must configure the account with an app.
Tip  To test that your parameters work as expected, click Validate.
  • Authentication Mode: Specifies the type of OAuth2 access token for the Dropbox account you want to watch.
    • Use Authorization Code: Use a Dropbox token generated dynamically. You must authorize with Dropbox to generate an access token, which expires after a four-hour session, and a refresh token that is applied automatically for longer access:
      1. Click Authorize.
      2. On the Authorize Dropbox dialog, provide the following credentials for your Dropbox account app:
        • App Key
        • Authorization Code
        • App Secret
      3. Click Authorize.
    • Use Token: Use a Dropbox access token generated before September 2021 that does not expire.
  • Access Token: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed. If Use Token is specified above, provide the OAuth2 access token for the Dropbox account you want to watch.
  • Refresh Token: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed.
  • Access Token Expiry: If Use Authorization Code is specified above, this field auto-populates after Dropbox authorization is completed.
  • Path to Watch: Provide a location on your Dropbox account to watch for changes, using forward slashes. For example: /MyFolder. To specify the top-level, or 'root', use a single forward slash: /.
  • Watch Subdirectories: To watch activity in the selected directory and all subdirectories, specify Yes. To watch activity only in the selected directory and not in its subdirectories, specify No.
  • Events to Watch for: By default, all actions on the specified directory are monitored, including adding (CREATE), changing (MODIFY), and deleting (DELETE) files (and folders, if applicable). To monitor only one or two of these actions, expand the drop-down and adjust as desired.
  • Note  Events trigger based on changes in file date. If a file is overwritten, a MODIFY event is triggered.
Output Attributes
See Also
Attribute Description
time Event time
source Event type
error.type
(Failure port only) Error type:
  • InvalidMessage: An error occurred while configuring this component, such as missing or malformed values.
  • DeadLetter: An error occured while connecting to an external resource. Examples may include connection issues, invalid credentials, or generic external resource exceptions.
error.message (Failure port only) Error message
file.event (Success port only) File action (Create/Modify/Delete)
file.path (Success port only) File path
file.rootName
(Success port only) File root name
dropbox.user (Success port only) Dropbox account
