FME Flow: 2026.2
Azure Event Grid Subscriber
The Azure Event Grid subscriber receives notifications from FME Flow topics and sends events to Microsoft Azure Event Grid topics.
Protocol Settings
  • Event Grid Topic Endpoint: The topic endpoint for the Azure Event Grid topic.
  • Note  To locate the endpoint, navigate to your topic in the Microsoft Azure portal.
  • Event Grid Topic Key: The Event Grid topic access key used to publish events to your Azure Event Grid topic.
  • Note  To locate the access key, navigate to your topic in the Microsoft Azure portal.
  • Subject: The subject to use for filtering and routing events.
  • Event Type: The event type for the specified Subject.
  • Event Data: The event data, specified in key/value pairs, that is published to the specified Event Grid Topic Endpoint.
