FME Flow: 2026.2
Update the FME Web Services URLs
If both of the following conditions are true when you installed the FME Flow web services, you must manually modify the FME Web Services URLs to Use HTTPS:
- You specified the FME Flow Web Application Server (that is, you did not connect to your own Apache Tomcat server).
- You specified Enable HTTPS with certificate.
To modify the FME Web Services URLs to Use HTTPS:
- Log on to the FME Flow Web User Interface (see Logging in to the Web User Interface).
- Open the Services page.
- Click Change All Hosts and, in the URL Pattern field, change HTTP to HTTPS. If required, modify the port number to the one that was specified during installation.
- When finished, click Save.
