FME Flow: 2026.2
Log on to the Web User Interface
To log in to the Web User Interface for the first time as an administrator following installation, specify Username admin and Password admin. You will be prompted to update the admin password upon initial use, based on the default Password Policy configuration.
What's Next?
Troubleshooting
If the FME Flow Web User Interface fails to present the login window, review the fmeserver.log, fmeprocessmonitorcore.log, and fmeconnection.log located in the FME Flow System Share, which is specified during installation: <fileserverUNCPath>/resources/logs/core/current
If you see errors about a failed database login in the logs and are unsure of the database password, you can provide it in plain text in the fmeDatabaseConfig.txt configuration file to test. The FME Flow services must be restarted after modifying the file.
For more troubleshooting information, see https://support.safe.com/hc/en-us/sections/25623298793101-Troubleshooting.
